ok, i got a weird one and need to help please.
when i am coming to a stop at the lights or whatever, a split second before the car stops it makes a kinda spitting noise, then surges slightly, then stops. they only way i can describe it is like when someone has just chewed off a bit of fingernail and spit it out.
'toop' kinda noise, lol. it isnt loud either, only audible when the windows are down.
the trans is playing up a bit, i.e. if the fluid level is just on high then it will slip around corners and thump into gear, it needs to be overful to behave. there is a bit of fluid wetness around the pan, but not enough to warrant a new gasket. the sump has wetness around it too and there is an oil drip from somewhere but i still get ok pressure.
just wondering if any one would have any clues? would a dodge gasket spit when coming to a stop? what about the vacuum valve on the trans? would a seal make that noise and not be leaking?
its doing my head in.
quaddy carb.
as far as i know all vac ports are in use or blocked. will have another look now.
i have been messing with advance/retard timing since dropping in this block and the spitting has been present the whole time. no matter what it is set on.
ouch, yeah was kinda hoping not to hear that. cometic head gaskets, not cheap.
did yours just spit when coming to a stop or all the time though? this is just a really quick 'toop' and thats it.
runnin fine otherwise.
