Results 1 to 4 of 4
Thread: lpg tuning
    vk commodore
    Apr 2006
    Default lpg tuning
    iv got a technocarb and european converter. iv changed the points dizzy to electronic n now its running like shit. wots the best way to tune it. it has 2 screws on the converter, 1 is for idle n 1 sensitivity. which is which n wots the best way to tune
    thanks
    VH + VK Gas Cars
    May 2004
    Probably not what you want to hear but my recommendation is take it to a gas fitter that knows about technocarbs and get it dialed in.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    what is the car doing? spluttering at idle? running lean? lower power? key things to pin pointing where its gone wrong. Hows ur timing?
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    the lightning
    Jun 2005
    under the Southern Cross
    if it ran fine before you changed is the ignition system then it cant be the gas carb set up. my money is on timing and or possibly running the wrong coil. did you get a coil suitable for electronic ignition? most points ignitions run a balast resistor to stop the points frying so quickly from arcing. look at your coil.... will give similar symptons to a stuffed carb
    Quote Originally Posted by one_and_only2004 View Post
    Sounds like you and your friend have a collective intelligence rivalling that of a door knob. Looks like the useless crap you fit to your car is the driver.
  1. tuning my s/c v6
    By Burnout_bro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2008, 07:42 PM
  2. Tuning the sub
    By Dayvo in forum Car Audio
    Last Post: 25-02-2007, 11:42 AM
  3. LPG Tuning
    By DF_Media in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2006, 09:33 PM
  4. Tuning an amp
    By robbie77 in forum Car Audio
    Last Post: 29-10-2005, 02:47 PM
