Hi i have an 81 VC Commodore that is stock, pretty straight too ... an old grannies car ..... my starter motor just carked it (or solenoid) .... i just got given a VL for free but its only good for parts is there any way possible i could change a few things from VL to VC like gearbox and starter etc or is there anything i can use for my VC off the VL .....thanx for your help and time.
the diff you could use and rear half of tailshaft will take off alot better
the whole k frame can be swapped over, cant it?
im pretty sure everything under the car can get swapped struts, k-frame, motor, gearbox, driveshaft, diff.
you can even swap the complete dash over with a LOT of work, and also the complete fronts too, but i wouldnt.
Alot is interchangable.. what stuff you plan on swapping?
