Troy711
Retired Old Fart
- Dec 13, 2003
- 7,692
- 167
- 63
- Location
- Canberra, ACT
- Website
- forums.justcommodores.com.au
- 2011 Mitsubishi Pajero GLS
Alot of people have been asking how to remove the steering wheel on a VE.. so here is a bit of a guide on how to do it.
Step 1:
Locate and remove the airbag fuse (look in the passenger footwell). I like to switch the car to 'on' after I have pulled the fuse just to check that I have the right one. It will come up with 'Airbag Fault' if you have done it correctly. Some people say to remove one side of the battery too, that is entirely up to you.
Step 2:
Turn the steering wheel 90° left
Step 3:
Feel behind the steering wheel and locate a square hole (circled in red)
Step 4:
This is where it can get fiddly. Put a flat blade screw driver in the hole with the blade running horizontal (as shown by the red line in the previous picture).
Basically you are trying to pull the retaining clip away from the airbag hooks. The clip system has been traced in red (on one side only) to give you a better idea of how it works. The green circles are the springs which hold both sides of the clip system together.
This is a close up of one side of the clip.
The screw driver blade will go behind the red circle and the two red arrows are where the airbag hook underneath. When you lever the screw driver upwards it will pull the clip across enough to 'pop' out one side of the airbag.
Step 5:
Turn the wheel 90° right and repeat. The airbag will now come off freely.
Step 6:
Unclip the blue and orange plugs that go to the airbag.
Step 7 (for total removal of steering wheel):
This is only going from memory (but it isn't too hard to work out what is going on).
Unclip the white plug in the center of the steering wheel
Step 8:
Undo the big torx nut in the middle using a T45 torx bit and you are done.
EDIT: I've been told a T50 works better but I haven't tried it myself.
Like I said, it is very fiddly and might take some time to actually get the airbag off but once you know what you are doing and how the clip system works it is pretty easy. If you have any questions or if I haven't explained something properly here just post and I will try and answer them.
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 8:
