simon.w
- Sep 5, 2007
- 332
- 10
- 0
- VE SSV
Took the car for a serious strap this morning, with lots of standind starts giving all it has (310rwkw!!) without any sticking, slipping or smell. This will make the pedal heavier ... but not badly. My wife took out the car today and said it was fine.
OK ... here we go:
Gently pry the front dash assembly forward;
Now remove the plug out of the light switch by pressing on the locking lug and pulling.
Put this panel aside now ... check the floor for any of the white clips that may have come loose and replace them onto the black plastic lugs on the back for the panel.
Now undo the left hand screw in the ECU socket under the dash
Now gently pull the underdash panel down and out ... check for the white clips again
Now undo the two screws that hold the heater duct:
Now gently manouver the duct past the clutch pedal and remove
push the clutch forward with your had hand and get a large flat blade screwdriver,and leaver the circular spring out of the side holes, then pull it out of the plastic retaining clip in the clutch pedal arm
Now drill a 1/8th" hole just above the spring retainer cut out in clutch pedal arm
Get a return spring 60mm long with it's end clips. I bought a 9/16 x 4" x 0.047 from Bunnings and kept shortening it bit by bit until it was the right length. This is the perfect return factor.
Clip one end through the hole in the clutch pedal
Now remove the lower bolt at the underside front of the dash with a 13mm spanner.
Now it's time to make the bracket. Get some 3/4" X 3/4" mild steel angle and cut it 150mm long. Drill a 21/64th (7mm) hole 20mm from one end. Make sure it is out far enough from the angle so that the bolt head can turn on the inside. Now drill a 1/8th" hole at the other end on the apposing side of the angle ... next to the inner angle. Now cut out a strip from that end 8mm in and 90mm long to accomodate the heater duct.
Now put the duct back in place and put the left hand screw in loosely so that it still has a lot of movement but wont fall out.
Now bolt the bracket in place, angling it back toward you, but not obstructing the hole for the dash clips. Make sure it is very tight. It's a bit fiddly getting the bolt in with the duct in place, however you can't get the duct past the bracket if it is bolted in first.
Now clip the other end of the spring through the bottom hole in the bracket. There is enough movement in the duct and flex in the bottom plastic to see what you are doing.
Now screw the duct back in place
Clip the under dash panel back in place
Put the screw back into the ECU socket
Get the front panel and plug the light switch back in
Now gently clip the panel back in place
Job's done! enjoy a non-sticking, non-slipping, non-sticking clutch!
Good luck!
OK ... here we go:
Good luck!
