Results 1 to 8 of 8
Thread: ve ignition wire help
    ve
    Jan 2011
    victoria
    Default ve ignition wire help
    hey guys does anyone know the easiest place to find an ignition wire in the engine bay of a ve omega?
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE International Sportwagon SIDI 3L
    Oct 2009
    what are you looking to achieve?
    if it's extra security, all ve's already have an immobiliser as standard- so a remote kill switch isn't much help.
    Jun 2006
    Elsewhere
    There is one going into the main fuse box R/H front of engine bay. Although tracking it down isn't easy. I had to unfasten mine & break into the harness plugs and use the the multi meter until I found one.
    ve
    Jan 2011
    victoria
    got some led fog lights from holmart and they have a control module that needs a 12v ignition wire
    Jun 2006
    Elsewhere
    Yep that's why I was looking too. Mine also has a relay that turns the DRL's off as soon as you turn parkers or headlights on. Seems it is illegal to have them on together.
    ve
    Jan 2011
    victoria
    yep thats exactly what mine has sounds like its going to be a pain in the arse to do
    i might have a look in the fuse box might find an easier way or get an auto elec in ha ha
    UFO's Avatar
    UFO
    Oct 2009
    wiper motor?
    only powered when ignition is on, but is safe enough to work on without blowing something up and keeps your work away from critical engine electrics.
    VE Omega Sportwagon
    May 2012
    Hey stirringaxe, do you remember what colour the wire was (red I assume) and which loom it was in (left or right side when looking at the fuse box front on)?
    Already mounted some DLRs but now need to power them... The auto-elec said to wire them into the parkers (like many on here), but I'd prefer to have direct power and then a relay to the standard lights so they switch off when they come on. The other problem with direct power from the parkers, is you can't use them on the odd occasion when they're needed without the DLRs on then.
    I've also put fogs in but the Omega loom doesn't have the provisions for them (like the up-spec models that are plug 'n' play). I've got the appropriate OEM switch but I'm not sure if you can just hack into it or whether I'll need and aftermarket one. This is probably one for the auto-elec...
  1. Ignition wire (red)
    By Dan_VX_Spac in forum Car Audio
    Last Post: 17-07-2009, 10:39 AM
  2. Ignition Wire on VY II
    By [ASLYVY] in forum Electrical Wiring / Questions
    Last Post: 02-12-2008, 07:44 PM
  3. Ignition wire
    By Dingo29 in forum Electrical Wiring / Questions
    Last Post: 02-11-2008, 05:03 PM
  4. ignition wire
    By norticus in forum Electrical Wiring / Questions
    Last Post: 16-03-2008, 12:36 PM
  5. how do u wire L.E.D neons 2 ignition?
    By bomner12 in forum Electrical Wiring / Questions
    Last Post: 02-09-2006, 02:33 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
