Ve V6 starting problem.
calais06
Donating Member
Sydney, NSW
VE Calais MY06
Hey all,
Tried doing some searches but couldn't really find what I was after.
I have a 06 ve v6 and over the last 2 days I've had a starting issue.
One was when it was dead cold and when I went to start it tried cranking maybe 5 secs longer than normal and didn't start, so I turned the key off and tried again then it started right away..
It was all fine for the rest of that day, and then the day after it did it at the petrol station when it was hot.. So its not temperature related, any ideas what it could be?
The car has 108,000km on it, and at the (I think 115,000km service) it gets spark plugs changed? Could this be the issue?
I change the oil every 5,000-7,500km, and maintain it well.. I'm changing the oil at 110,000km, so should I do the plugs then if it's possible to be those?
Sorry for rambling on haha.. Any ideas/help is appreciated.
Sent from my iPhone using Tapatalk
stick3
newcastle nsw
vz sedan vs ute gsx1400
have u change air and fuel filters
Supe
Supe
Rural NSW
VE Calais 6.0
Low fuel pressure, dying fuel pump? Ask Holden to check the logs.
vicarious
47
SA
VE2 SV6 SPORTWAGON
hows the condition of the battery?
calais06
Donating Member
Sydney, NSW
VE Calais MY06
Air filter is a new k&n panel that came with the OTR, havent changed the fuel filter, always run 98 octane.
About a month ago I had the logs checked and there was nothing about fuel filter, I'll get it checked at the service.
The battery dies pretty quick, like when installing the amp the battery didn't have enough power to fully crank over, but I assumed the battery would b ok cos it was cranking fine, just not firing?
Thanks for the ideas :)
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
There arent any "logs" unless an event occurs that logs DTC's.
Generally when an engine related fault occurs the engine light will illuminate.
stick3
newcastle nsw
Fuel filter is non serviceable
what a stupid pita idea, u dont want to get any dirty fuel also i will be adding a capful of metho to help evaperate moisture,every few tanks
RiCeY
Australia
Where will it evaporate to? The tank is sealed and the fuel cap only allows air in, not out.
Longman
Newcastle NSW
VE Calais V 6.0 Auto
Time for a battery change? Have you ever replaced it since getting the car?
