Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Like Tree1Likes
Thread: Ve V6 starting problem.
    calais06's Avatar
    calais06 is offline Donating Member
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Default Ve V6 starting problem.
    Hey all,
    Tried doing some searches but couldn't really find what I was after.
    I have a 06 ve v6 and over the last 2 days I've had a starting issue.
    One was when it was dead cold and when I went to start it tried cranking maybe 5 secs longer than normal and didn't start, so I turned the key off and tried again then it started right away..
    It was all fine for the rest of that day, and then the day after it did it at the petrol station when it was hot.. So its not temperature related, any ideas what it could be?
    The car has 108,000km on it, and at the (I think 115,000km service) it gets spark plugs changed? Could this be the issue?
    I change the oil every 5,000-7,500km, and maintain it well.. I'm changing the oil at 110,000km, so should I do the plugs then if it's possible to be those?
    Sorry for rambling on haha.. Any ideas/help is appreciated.
    Sent from my iPhone using Tapatalk
    vz sedan vs ute gsx1400
    Jul 2008
    newcastle nsw
    Supe's Avatar
    Supe is offline Supe
    VE Calais 6.0
    Jan 2008
    Rural NSW
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    VX acclaim S2
    Oct 2009
    Quote Originally Posted by stick3 View Post
    have u change air and fuel filters
    Fuel filter is non serviceable
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Air filter is a new k&n panel that came with the OTR, havent changed the fuel filter, always run 98 octane.
    About a month ago I had the logs checked and there was nothing about fuel filter, I'll get it checked at the service.
    The battery dies pretty quick, like when installing the amp the battery didn't have enough power to fully crank over, but I assumed the battery would b ok cos it was cranking fine, just not firing?
    Thanks for the ideas
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    There arent any "logs" unless an event occurs that logs DTC's.
    Generally when an engine related fault occurs the engine light will illuminate.
    GOLD Level Holden Technician.
    315rwhp
    Jul 2008
    newcastle nsw
    Quote Originally Posted by kizza50 View Post
    what a stupid pita idea, u dont want to get any dirty fuel also i will be adding a capful of metho to help evaperate moisture,every few tanks
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Where will it evaporate to? The tank is sealed and the fuel cap only allows air in, not out.
    315rwhp
    VE Calais V 6.0 Auto
    Jan 2008
    Newcastle NSW
    Time for a battery change? Have you ever replaced it since getting the car?
  1. Starting problem
    By ch1mp in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2010, 09:32 PM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 08:56 PM
  3. starting problem
    By whatisnttakenalready in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2007, 09:29 AM
  4. VS starting problem
    By mrnathan in forum Electrical Wiring / Questions
    Last Post: 06-06-2006, 08:46 PM
  5. Starting problem
    By UtelemO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2006, 04:30 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
