Alternator Warning ?? VE Alloytec
greenacc
Searching for the billion
VE Berlina
So i went for a drive today and just as i pulled into a carpark the Alternator warning popped up on the centre screen. It came up again after shopping then disappeared.
It's the first time i have seen this warning and i've had the car over 2 years. It's got 180,000 k's on it.
Did a search and found an old thread about a rusty terminal so i will check that out. Has anyone here had to replace their Alternator on a VE Alloytec ? I see Holmart has them for about $290 if i need to go that way... would i need the 100 or 120 Amp unit ? It is a series 1 Berlina.
greenacc
VE Berlina
Hasn't anyone had this issue before ?
I checked what i can see of my alternator and it is a 100 Amp unit and i can't see any corrosion on anything, but its hidden away pretty well se i can't see much.
Sean880
VIC / NSW
2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
With those 180000 kms and operating hours on the car the brushes in the alternator will be badly worn and need replacing. They are a wear item and do not last indefinitely. At the same time change the voltage regulator . Or you can renew the entire alternator.
Benboy
Hill River, SA
2007 SVZ Wagon
Take the car to an Auto Electrician to have the problem diagnosed. To do otherwise could be a complete waste of your money as it seems you do not have a very high understanding of automotive electronics. Good luck.
Sean08ssv
Ve ssv ute
Follow up?? Same issue here
greenacc
VE Berlina
I just ignored it and it went away!
It's happened to others on here, bloody hot day, aircon on high alt light comes on for no reason.
