VE Handbrake
South West Sydney
VX S pac manual/VE sportswagon omega Z-series
How does a VE handbrake work what's different from earlier models?
I can have my VE in park with handbrake on when I lean on front or back, the car shifts/moves is this normal
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Works the same as earlier models.
How much does it move? How far does the handbrake lever come up when you apply it?
Sandman
Challenge Accepted
Too many
Sounds like the handbrake needs tightening
South West Sydney
It's been that way since new I asked the service guys at holden they recon its normal
huthy14
Canberra Act
ve ss
Why don't u just put it in neutral and put the hand brake on and the see if the car moves.
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
The handbrake shoes float in the drum part of the rotor so there will be a tiny bit of forward/backward movement.
greenacc
Searching for the billion
VE Berlina
yeah as ricey said car will roll a tiny bit maybe 1 inch at most then the wheels lock. It feels worse
than it is.
ljeff7
Holden Commodore SV6 Ute 60th Anniversary
I have a problem with my handbrake aswell. On a reasonable incline my handbrake will not hold the car for a hill start, i have to balance the clutch and the throttle to keep it in the same place without moving? What can i do?
rx2_freak
Smokes, let's go.
Churchill
SSV Z SERIES SPORTWAGON
Learn to drive manual.
nah seriously get your handbrake tightened, any place that services cars should be able to do it for you.
gossie
Gold Coast.
VE International 3.6L
Heel and toe is the go for that problem.
