Exhaust
purple ss
queensland
04 VZ SS / 07 VE SS
Well l just put a cat back 3in XForce exhaust on and l am very disappointed with the sound.
Went on youtube and that sounds good l will go with that, yer right. You can hear the sound of the exhaust when you
get up it,got the missus to drive and could hardly hear come in the drive way.Drive it at 60ks and it sounds like a standed one.
191kieran191
Collinsville
VE Series 2 Thunder Ute
how is that a bad thing car is quite while driving sensible and loud when u get up it sounds like a perfect exhaust if u ask me
mattyh83
2010 VE SSV
Did you get the one with the adjustable valve?
EDIT: wait for it to carbon up a bit as well.
Sent from my GT-I9505 using Tapatalk 2
Munz
Right Foot Action
Brisbane NTH
VZ Calais LS1 / VL RB30e daily
Buy a cam - you'll hear it coming from 8 blocks away
Maybe invest in some extractors and hiflow cats they will help with the sound
Lumps of cheese
welcome to the machine
45
Warrnambool
83 vh sle, 4x4 hilux, 03 monaro, 07 nightrain
Xforce, nuff said.....
HEXEM
ACT
VE II SV6
sounds like xforce may have made some slight modifications to eliminate exhaust drone when cruising around at low rpm's.
mpower
Sounds like an improvement, xforce are known for terrible drone at low revs/cruising speeds.
Sent from my HTC One XL using Tapatalk 4
purple ss
queensland
04 VZ SS / 07 VE SS
Thanks for that, maybe they have made some improvements.l will put extractors and cats on later on hoping that will give it a better note, thanks
VTSS304
Australia
VT SS 5.0L Manual
Like everyone else said, let the exhaust bed in a bit, it will get a meatier sound soonish, also check that your car is the same as what you heard online manual/auto, cam/stock, extractors and cats etc There are lots of different things that effect the exhaust sound. Check that they definately did the 3" too because it should be pretty loud.
