Results 1 to 10 of 10
Thread: Lpg my10 ve
    06 VZ 9C1 Wagon
    Sep 2009
    Default Lpg my10 ve
    Hi All,
    Just wondering what the throughts are of holden sticking with the 4 speed Auto on the new MY10 VE LPG.
    One really has to ask if they are really serious about alternative fuels with a decision like that. While I wouldn't expect to get the SIDI engine seeing as it would run only Petrol for about 10 minutes a day, I do expect the much needed 6 speed auto. Yes, the 6 speed auto hasn't been mated to that engine before, but the relatively small engineering required would simplyfy the transmissions to 1 automatic across the range.
    And on the same subject, where is the LPG wagon? I have seen quite a few after market conversions now, while spare wheel space is not exactly at a premium with the sport wagon, it still makes sense and the spare wheel could be an upright space saver or an option to not carry one at all.
    Looks like an aftermarket conversion of a 3 year old SIDI wagon will be the one for me.
    Feb 2007
    I was about to start a similar thread about this topic.
    In my opinion, Holden decided to keep the 4-speed automatic for the dual-fuel Commodore for the following reasons:
    1. To keep prices down (read: to keep GM's profits up)
    2. To ensure that driveability remains a step BEHIND petrol-only variants
    3. To minimise development costs
    Both 2 and 3 ensure that the final result is seriously compromised.
    You're right in saying that Holden is not taking the alternative fuel options seriously. They spend $millions on the development of direct-injection petrol engine and yet they spend only a small fraction of that on engine variants that run on fuels such as LPG when clearly there is a large market for engines optimised for the latter.
    It's safe to say that the 'LPG is for BBQs' stigma will live on... or at least until Ford releases their third generation dedicated LPG engine in July 2010.
    Regards,
    Dave
    Injected CNG, LNG & LPG: The only way to go better!
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    isnt holden releasing a dedicated gas ve soon? maybe it will come out then, so they kept the old going untill the revised comes out?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Cav's Avatar
    Cav
    Cav is offline Donating Member
    VE International; AUIII XR8 Ute;1981 TF Cortina
    Oct 2006
    Primbee NSW
    I have a VE International on gas and out on the open road it does seem to change back a gear more often when running on LPG.
    It seems well mated to this gear box
    But I agree, if they supply the old gearbox in the new model then they should be much cheaper.
    My LPG was aftermarket done by the dealer as they had run out of LPG Internationals.
    I wonder if they would do the same for the new model and how the new auto would go on gas.
    Methinks it may start changing back a gear or two or three on hilly country, which could turn out to be a pain in the arse.
    The newer autos are designed for more fuel efficiency, maybe they are not needed with gas
    Feb 2007
    Quote Originally Posted by Cav View Post
    You can bet your life that any gains experienced with extra ratios with a petrol engine would be experienced with a gas engine too. I wouldn't be surprised if the dual-fuel VE Commodore's fuel consumption drops to 12.5L/100km or so if Holden matches the engine with a 6-speed auto.
    Expect Ford's new E-gas engine to use around 12L/100km with the standard 5-speed auto too.
    Regards,
    Dave
    Nov 2007
    Icom have a DIRECT injection liquid injection system that will allow the direct petrol injection engines to be run on liquid injection. If you thought that port injected liquid LPG injection was good wait till you see what it can do for the new commo's and the gains that can be had.
    Feb 2007
    Quote Originally Posted by blownba View Post
    YEAH BABY!
    10L/100km on a Falcodore ON LPG here we come!!!
    Regards,
    Dave
    Feb 2007
    Further to blownba's post above, I've done a little bit of research.
    Here's what I came up with:
    Source: Powertrains - Automotive Engineering International Online
    Regards,
    Dave
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    mmmmmmm noice, so when are one of you guys going to buy a new commodore and be a guinnea pig for us, i cant wait to see results from it
    Feb 2007
    BRC (owned by IMPCO) also have a direct injected LPG kit available in Europe, although it is a vapour-phase system.
    BRC Gas Equipment - Sequent Direct Injection
    Regards,
    Dave
  1. new sidi engines for the my10 model holdens
    By vp5lute in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-09-2009, 08:12 PM
  2. New seats for my10? anyone know?
    By mooks6669 in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-08-2009, 04:34 PM
