RustyCardores
- Jul 25, 2009
- 4
- 0
- 0
- VE SSV Sportwagon
Has anybody found someone who can reprogram the 6spd auto in an AFM SSV Sportwagon?
I have two things I would like to change....
1: Add a "2nd gear start" setting. Just like in my Landcruiser, I would like to push a button and have 1st gear ignored while the button stays depressed. 1st is quite low and "off the line" throttle control needs to be controlled or the thing launches itself.
Using active select for second gear starts makes it a lot nicer for casual driving around the burbs. This brings me to my second wish.....
2: Make active select stay in the gear selected. It bugs the living crap out of me that the auto changes down even when I don't tell it too. Having a "pseudo" manual option should be just that... "manual". ie it should stay in the gear that I put it and not go back to 1st just because I have pulled up at the lights ....and if I am silly enough to try and take off in 4th gear and it stalls, then so be it.
It's a pain while on the move too, as quite often I have been having a play and just moments before I downshift, the transmission does it own downshift and all of a sudden I am down two gears. This totally wrecks the "drive" and also makes me look like a right twit to others. lol
I know you can watch the gears on the dash display, but I don't want to be looking there all the time during "play", plus I can't see the stupid red lights they have used anyway. (A common complaint for those of us over 40 here.... I wish there was a green or white option, but I digress)
Rusty
Rusty
