Results 1 to 16 of 16
Thread: capa otrcai with maf and no tune
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Wink capa otrcai with maf and no tune
    hey guys just a quick easy one i hope im looking at a capa otrcai and im gonna keep my maf and no tune just wondering how many people have done this? will i see gains without a tune? or will it be sluggish and not run right? thanxs scott
    VE SV6 ute
    Apr 2009
    vic
    It will be fine, the ecu should adapt over a few days so it won't run lean or anything. Will still pickup kw and nm. And def better fuel eco.
    You planning on any mods after this?
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    thanxs for the input, just the exhaust and extractors then cats and just enjoy for a while
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    it will run, you wont have any major issues. it will run a little on the rich side should pickup a bit of power. don't believe any of those the ecu will adapt wives tails.
    i'd get a mail order tune atleast to take full advantage of the otr.
    VE SV6 ute
    Apr 2009
    vic
    VE SSV 9.5
    Jan 2010
    from what ive herd you will need a tune if you get extractors otheriwse the check engine crap will keep flashing
    thats prob the main reason i did exhaust extractors otrcai and dyno tune all at once
    Jun 2004
    Quote Originally Posted by ssavage View Post
    This is true for changing the CATS cat back extractors(as long as the cats aren't moved) and otr which retains maf should not throw a check engine light.
    Jun 2004
    Quote Originally Posted by kuzman89 View Post
    But the ecu does adapt...
    Not really. being a ecu can adjust whats called long term and short term fuel trims. being can lean or enrich the fuel mixtures at cruising speeds this is aimed to keep emissions in check.
    in terms of performance though when you got to WOT(wide open throttle) situations the ecu goes into closed loop meaning all that is being measured really is engine load (MAF) and this is being used as a reference against the ecus ignition and fueling tables which are static and cannot be changed unless the car is tuned.
    your car must have a cop chip??
    VE SV6 ute
    Apr 2009
    vic
    Well when I said adapt, I didn't mean in the same way as a tuned ecu would lol.
    MY9.05 SSV UTE
    Sep 2009
    i just brought a ramjet OTR with the MAF still on and have noticed a huge diffrence, before this i had a SS induction growler kit.
    09 SSV BLACK UTE. RAMJET OTR, 3 INCH XFORCE CAT BACK,
    Grennan's Avatar
    Grennan is offline Slayer of Stupid Threads
    Manual VX SS SII
    Mar 2007
    Glen Waverley, Victoria
    Quote Originally Posted by benji09ssv View Post
    The SS inductions stuff is...well one step short of being shithouse.
    How is the Ramjet? I was going to wait to see how it performed but after I saw the right angles on the intake I decided against getting it.
    - Black Manual VX SS Series II -
    Stealth Mode Activated
    JonnyDe's Avatar
    JonnyDe is offline Donating Member
    VE SV6
    Jan 2010
    Ayr, North Queensland
    Quote Originally Posted by monaro327 View Post
    The modern ECU takes readings from everything constantly. Plug in a Tech2 unit and you can see everything which is happening. As soon as you put in your 98 octane fuel the ecu will advance the timing further as it realises it can. And will keep advancing until knock occurs, then bring it back. So with cooler air coming into the motor. The ecu can adapt.
    But you gotta remember is dosnt adapt for performance, just optimum running condition. So you will need a tune for full benifets
    Jun 2004
    Quote Originally Posted by JonnyDe View Post
    If an ecu can adapt to intakes then why do i have dyno sheets showing different AFR for 4 different intakes. stock intake shows 1 afr which is different for airhammer and different for otr and different again for aircharger.
    Also your wrong about the octane tables, there are 2 table high and low octane, the ecu can move between these tables but not above or below....
    i never said the ecu wasn't reading from several different sensors i have a tech2 but everything is basically ignored at WOT except the key stuff. WOT is closed loop and referenced as per the tune tables.
    voodoo-VE-SS's Avatar
    voodoo-VE-SS is offline voodoo1
    VE commodore ss
    Feb 2010
    adelaide
    Fitted a ram jet 3 weeks ago. engine light keeps coming on. norrowed it down to oil in K&n filter contamenating maf.any other thoughts would be appreciated.
  15. #15
    VE commodore ss
    Feb 2010
    adelaide
    had the ramjet on my ve ss 4 weeks now. my car is brand new. Still cant get my car to stop engine light comming up bank1 bank2 running lean.thought it was k&n filter contamenating maf. but it isnt. put back to standard,no codes for a week an a half. I work in the car industrey so i have got the use of a tec 2. I am dissopointed GM Motorsport advertise ramjet just bolts on. i will have to folk $700 bucks to have it tuned now. Our leave it off and waste $570 bucks. Has anyone else had exsperiance with a ramjet.
  16. #16
    08 VE SS V
    Apr 2010
    voodoo
    get the car tuned - if possible, by Sonny if ur in Sydney
    with OTRs, air is rammed in so ECU thinks there too much air, hence more fuel - runs rich, can trigger engine lights/codes.
  1. [LS1] Capa superchargers
    By DARK SIDE in forum LSx Development and Modification
    Last Post: 08-01-2010, 10:56 PM
  2. MAFLESS Tune w/ OTRCAI
    By bakes25 in forum General
    Last Post: 22-10-2009, 05:12 PM
  3. Capa 5l Sc kit question
    By WhyallaVp in forum V8 Development and Modification
    Last Post: 12-08-2009, 12:32 PM
  4. [SA] Capa vortec kit
    By sus_calais in forum Parts And Other Items For Sale
    Last Post: 13-05-2009, 06:13 PM
  5. Capa VL Turbo kit
    By cypher967 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-03-2009, 11:46 AM
