-vkhg
- Nov 16, 2006
- 142
- 2
- 0
- Age
- 34
- Location
- Geelong
- 2005 VZ SS
g'day guys.
firstly the car is an 07 VE SS Manual with just under 70'000 kms on the clock. fully stock to my knowledge.
ok, so ive recently had a suspension and brake check done by pedders as i was having a knocking noise in the front end and somewhere in another thread someone mentioned to get the check and report done by pedders.
a number of things came up:
brake and clutch fluid need flushing
front strut mount plates shagged
front sway bar links worn (no preload) - anyone care to explain preload?
and rear shocks leaking (require replacement)
just wondering what you guys think i should do. i want to get rid of this front end knock (both sides) and ive had strut top problems on a previous car (which was a vn calais =\) which now that i think about it sounds very similar. but ive read in the recall thread that the G8 had a similar problem and the fix was "Replace Front Lower Control And Caster Arms". so im not totally confident in getting the strut tops/sway bar links replaced if this will not fix the problem.. thoughts?
also re: the rear shocks, im gonna get her lowered soon anyway so ill replace shocks then.
