Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Like Tree4Likes
Thread: Deactivating the afm
    9.5 SS VE
    May 2011
    The Entrance
    Default Deactivating the afm
    Ive put a 2 1/2 inch exhaust system on my VE SS. When the AFM cuts in it gets too noisy and a small vibration . Im thinking of getting the AFM deactivated , but does anyone know how much extra fuel it would use . Im doing 160 k's each day on a freeway.
    2010 SR POS
    Jun 2009
    berwick
    all depends on your right foot if you spend a lot of time on the freway you will notice the diffence but do you want to put up with the noise on the freeway
    please adjust the settings on your sarcasim detector it will be needed
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by excopss View Post
    From what i understand that's when you get the most out the AFM so maybe look at getting a better tuned exhaust or some good quality sound proofing like Dynomat.
    VE SSV SE 2010
    Apr 2010
    if you get a tune and deactivate the afm ur fuel economy will improve significantly
    SSV Redline is offline You Ride I Ride
    VE Series II SSV Redline Sportwagon
    Mar 2011
    I'm more worried about your vibration and noise on the highway when your AFM cuts in. Doesn't happen in my twenty ten wagon but I have masked the noise with Dynamat. Get your exhaust system checked.
    Postings on other threads suggest the AFM is a sham to make V8's look 'greener' in the eyes of new holden buyers. If re-tuning and deactivating the AFM improves economy and your right foot doesn't need to touch the firewall at every green light then I'd be doing the same.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    The problem with that theory of more power less accelerator is when you've got that extra power you tend to use it.
    Series II SS
    Jul 2010
    Hey mate, what brand did you get fitted?
    IF YOU BUILD IT THEY WILL COME.... STILL WAITING LOL
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    There are a lot of variables, but just going by Holden's figures, the AFM saves about 1L/100km.
    So you will use an extra 1.6L of fuel per day. Bugger all really...
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    VE SS Series 2
    Mar 2011
    Newcastle
    Drive it for a week in sport mode, AFM dont work then and then you will be able to see if there is a difference, I'd near on bet you wont see much of a difference. think they say AFM is good for about 1L/100 khs better so you might use about 5L/week more
    I do 50/50 city highways khs, 110 each day, i have a tune done and i went from 12.5L/100khs down to 10L/100khs, used to have to fill up after 4th trip now i can do a full week on 1 tank.
    VE II SSV Sportwagon
    May 2005
    top of Sydney basin
    I have the standard exhaust and I get a slight driveline vibration when the AFM is operating. The AFM must change the engine balance slightly when dragging around the unused pots. Does the AFM hold open exhaust valves or something??
    The vibration is non-existant when in 8 cylinder mode. I too would like to know if the AFM could be deactivated so I could compare fuel usage for my normal driving conditions.
    It would be nice to have a switch!! Maybe there is a fuse or CB somewhere...
    VE II SS-V Sportwagon
    May 2005
    top of Sydney basin
    Quote Originally Posted by Nanoxcel View Post
    Sounds interesting Nano. When its tuned, what do they do or what can they actually change?
    VE SS Series 2
    Mar 2011
    Newcastle
    Quote Originally Posted by Thumpin View Post
    • Ignition advance
    • Knock retard
    • Fuel mixture
    • Idle speed
    • Idle control
    • RPM limiter
    • Speed Limiter
    • Transmission shift points
    • Transmission shift firmness
    • Transmission torque reduction
    • Transmission shift pressure
    • Torque converter clutch
    • Fan on/off temperature thresholds
    • Speedometer calibration
    9.5 SS VE
    May 2011
    The Entrance
    Yes SSVRedline ... The vibration was there befor the exhaust was put on . Only very slight . Everyone tryed telling me it was a tyre problem . After I put the exhaust on it came out in noise as well . Took it to Holden and found out it was the AFM . They said all of them do it ,but Im one of about 10 percent of people that picked the vibration was there . Because a V8 cant run smoothly on 4 cylenders .
    9.5 SS VE
    May 2011
    The Entrance
    Hi Cruzer . I fitted a 2 1/2 inch XForce system . Only took 40 minutes to put it on and a bit to line up both the tips . Sounds good . Just sounds like its farting with the AFM.
  15. #15
    9.5 SS VE
    May 2011
    The Entrance
    Thanks heaps everyone for your respons . Ive been doing the drive in manual mode . It sounds heaps better . And no vibration . Not much more fuel . So going to go ahead and get it deactivated with a tune .
    Thanks again . excopss.
  16. #16
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    i know you've already decided, but this is why I think AFM is more than a little useless.
    AFM only kicks in when you are at speed on a hwy (not during stop start city driving). but the modern 8's are actually very efficient when it comes to hwy cycle... i know because I have a small 6 and when I look at 8's fuel use it isnt much difference at all. the problem with 8's is when they are in traffic stop start. now.... if they could somehow develop an AFM that runs in stop start traffic, THAT would be worth having. but for hwy use only? disable it. more trouble than its worth. my 2c anyway.
  17. #17
    2011 VE Series II SSV Redline Ute
    Mar 2011
    Cranbourne
    Quote Originally Posted by UFO View Post
    Thats strange, my 2011 Redline Ute when driving around town I notice AFM cutting in and out at speeds between 40-70km as well as constant 80km and 100km HWY speeds...
  18. #18
    SSV Redline Ute (Voodoo)
    Apr 2011
    Liverpool
    I have a 2011 redline ute auto with afm, I got the whole afm taken out when i put a cam in it, why buy a v8 only to get it to run on 4 cyl, so no i have a L98 instead of an L77. Had other mods and it drives great. Marranos at Croydon done it, Thanks Sonny
  19. #19
    May 2005
    top of Sydney basin
    Quote Originally Posted by unitary View Post
    Yer, mine does the same. Any light constant throttle condition and in she kicks.
    As mentioned earlier, the AFM does cause a little vibes most noticeably around 100-110 K's.
    I drive in mostly stop/start Sydney crap traffic. My last tank got me 515 K's for 63 litres. That equates to 12.23 litres per 100 K's. That's about the same as an ecotec V6 and much better than my Bro's Kluger which uses 14.8 per 100 k's on a good tank.
    Who in Sydney (South) knows what they are doing with these tuning make-overs? Any experience?
  20. #20
    Commodore
    Jun 2004
    NSW
    what was your average speed ?
  21. #21
    UFO's Avatar
    UFO
    Oct 2009
    well cutting in and out isnt exactly going to give you much benefit bud. what i was trying to say is that AFM will only really benefit if you sit at a constant speed.... and driving around town is NEVER going to be constant. i say "hwy" but I pretty much mean any long stretch of road with no traffic lights or traffic. speed isn't the factor, its the stretch of road. and if you are in a 40km zone, you arent staying at that speed for very long without having to brake or accelerate.
  22. #22
    May 2005
    top of Sydney basin
    Quote Originally Posted by Xonar View Post
    From memory it was 31 K's.
  23. #23
    9.5 SS VE
    May 2011
    The Entrance
    Yeah mine was cutting in and out at all different speeds . Mainly as soon as the car thought it was cruising .
  24. #24
    2010 CalaisV Sportwagon V8 Auto
    Mar 2004
    Lol, I went into Holden today to ask if they could disable it. Spoke to 4 different people they all looked at me blankly, one even asked what afm was... Thats when I walked out...
  25. #25
    UFO's Avatar
    UFO
    Oct 2009
    Quote Originally Posted by unitdiplomacy View Post
    Woden by any chance?
  1. Deactivating VS airbag
    By simmons001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-07-2009, 10:36 PM
