So, ever since I have owned my wagon whenever I take a tight right hander and load up the left front wheel I get a knocking/grinding sound, I have 22's now but even when I had the standard 19's on it still happened. So got a servive yesterday and they noticed wear on the front left and right strut spring plate, worse on the left. Found a generic picture as reference, will get actual ones soon.
Anyone come across this before, i'm thinking sagging front struts?
TELLING IT HOW IT IS SINCE 1982
I've had it happen to my driver's side front in my old ute. Happened in a prang but is apparently pretty common. Decent pot holes can bend the struts enough to scrub the inside edge of the tyre. It can go missed as well. I had my ute repaired and got it back all signed off with wheel alignment report and everything. Took it back with the scrubbing and a slightly off-centre steering wheel and found the bent strut.
Do you have the correct profile on the 22s so the rolling diameter is the same as factory?
Silver Certified.
either Bent strut OR needs camber adjustment done as you can lean the tyre away from the strut with a camber adjustment
also check the inner gaurd for rubbing as you may have a caster problem also...
Yer profile is good on my 22's and it's rubbing nowhere but on the bottom of that spring retainer.
Has to be something out shape cause was happening with 19's as well.
yeah get a wheel alignment done with a printout and ask them to adjust the front camber
hey guys ive got the same problem on my vx ss, front left has scrub marks on the exact same spot. While i was changing the castor bushes i noticed that the radius/strut rod on the left side was way closer too the sway bar than it was on the right (nearly touching) so ive ordered a new set of radius rods and hoping this will fix the problem, what do you guys think?
Any ideas guys? I'm really stumped as to what could be causing this...
There is a piece of metal that is attached to the chassis on the inside of the wheel well, about 15cm long and 5-10cm wide. It hangs down below the chassis and on my car it was bent up and inwards, so whenever I went full lock the inside of the wheel would rub on it. My mechanic just removed them lol. Issue solved. They didnt look like they did anything as they didnt hold anything in place. Take your wheel off and a have look?
