Hey All,
Just wondering will sedan suspention be able to fit into the wagon?
Either the springs by themself or springs and shocks?
Thanks for your help!
WARNING - If you value your life as much as I value my car, Dont F*#K with it.[/I]
My Ride:- http://forums.justcommodores.com.au/...on-cammed.html
Firstly its suspension lol
Not sure bout shocks im pretty sure there the same.
With the springs the only difference is the rears with load rating i think if you put sedans in a wagon it will sit a bit lower.
I thought it looked WRONG!!!!!! I hate spelling never was any good at it lol.
Thanks for the reply tho
thats cool man im not the best at spelling either if i find a word i cant spell i type it in to google lol.
Front springs are the same - rear springs are different - they're the same as the utes. Also not sure about the shock swap-over. Give holden spares a call and ask for the part numbers.
I just found out from Pedders that the front shocks and spring will be fine to swap over from a sedan to wagon, the rear spring can be used aswell you will just need to get new rear shocks.
the rear will fit but the bottom spring seat is a different height and the shock has a bit larger bore with different valving and the coil is a different rate.
