Results 1 to 12 of 12
Thread: Where can I get the heater hoses that go alone the side of the motor not on top?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default Where can I get the heater hoses that go alone the side of the motor not on top?
    One of them is leaking and I've always thought they looked untidy since i removed the engine cover, so I thought I'd kill two birds with one stone.
    P.S you can see the hose in the pics on the thread below
    VE SSV SE 2010
    Apr 2010
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Ah No, why?
    bladerunner's Avatar
    bladerunner is offline AUSTRALIAN MADE AND OWNED
    VE SS UTE
    Nov 2010
    brisbane nth
    Default re; heater hose
    go onto the ls1 forum and do a search if you can or check the archives as theres a bloody long thread on this subject and i believe a fix as well.
    im out of my mind at the moment...please leave a message
    VE SS UTE
    Nov 2010
    brisbane nth
    2012 S2 SV6 Sedan
    Apr 2010
    What I did was buy the VZ hoses (4 of) and used enzed hose joiners (with clamps), you need to use joiners as there is no external heater tap. You will need to shorten each hose by about 100mm or a bit more. Some have used the factory hoses from the VK commodore as well. I liked the VZ ones as they are shaped to run along the side rail.
    Phil
    If your not living life on the edge, then your taking up space!
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Thanks for the help guys really appreciate it.
    MY 9.5 SSV Sportswagon M6 & 08 prado D4D GXL M6
    Nov 2005
    Bushfield, Vic
    Yep i used VK V8 ones. They have right angle bends to go on the engine and there cheap. I'm not a big fan of their spring loaded hose clamps either, so i used normal ones on the firewall as one of them didn't feel right. I can post pic's if you want.
    Cheers.
    BTW how's the gas going?
    [CENTER][URL="http://forums.justcommodores.com.au/showthread.php?p=490264#post490264"]
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Thanks azzss, the gas is great cheap ($40-45 for 70-80Ltrs) and i get the same economy as fuel I would do it again with the next car as well.
    06 VE SS
    May 2009
    Rockingham, WA
    Done it today,the Vk V8 heater hoses work well(use the longer of the two x2). All up it cost about $40 with some clamps, i will put some photo up tomorrow.
    VE SS-V
    May 2010
    Quote Originally Posted by scouser king View Post
    So you have to buy two sets of the hoses?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I would think you'd be able to buy them as two separate hoses.
  1. heater hoses
    By base308 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-08-2010, 11:22 PM
  2. heater hoses on v6
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2009, 06:44 PM
  3. Where are my heater hoses?
    By Lewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-06-2009, 12:34 PM
  4. VS Heater Tap Hoses
    By Mickyh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2008, 06:17 AM
  5. New heater hoses now no heat?
    By fergies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2008, 03:16 AM
