Results 1 to 7 of 7
Thread: Noisy when accelerating
    Homer's HSV's Avatar
    Homer's HSV is offline Homer Simpson
    VE E3 Clubsport
    Feb 2010
    Default Noisy when accelerating
    Firstly nothing in the engine bay is loose eg covers and plastic clips broken.
    It happens when i just start the car and on hard acceleration its like a rattling noise but only happens as soon as you put your foot down then it quickly goes away the car runs 100% no issues with fuel consumption engine lights etc. It happens with air con on and off going to take it to Holden this week but wanted to know if anyone has had the same issue.
    Cheers Eddie
    CHECK OUT MY RIDE
    OPERATOR GIVE ME THE NUMBER FOR 911
    HOMER J SIMPSON
    ve ssv/vr calais V6 turbo oneday N/A Track car
    May 2010
    Rockhampton QLD
    If its only when you hit the pedel hard might be engine ping, its a metallic sounding rattle.
    Mine never did it i got a tune and at only does it in a high gear at low rpm
    hows the fuel that your using.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Sounds like its pinging which is a quick way to kill the engine.
    Does it have an aftermarket tune?
    What fuel do you use?
    Silver Certified.
    May 2010
    Rockhampton QLD
    HA HA thats what i was getting to except i forgot to it the word pinging in after engine. I will fix it up
    VE E3 Clubsport
    Feb 2010
    I just came back from a drive from Brisbane and put reg unleaded in it just to see if there was any difference in on my trip back i used it all the way home and still have some in it i have had it tuned if i use what i normally use with is 98 fuel will it go away
    Cheers Eddie
    CHECK OUT MY RIDE
    HOMER J SIMPSON
    May 2010
    Rockhampton QLD
    VE E3 Clubsport
    Feb 2010
    Thx mate will drive it easy till i nearly run out then put premium back in
    But as i wanted to see the difference and normal unleaded was using approx 1.5 litres per 100km more on the highway from Brisbane till home
    Thx heaps for the responses was thinking something stuffed up.
    CHECK OUT MY RIDE
    HOMER J SIMPSON
  1. Delay on accelerating
    By bigal in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-04-2010, 10:21 AM
  2. howling when de-accelerating
    By hsv91ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 11:14 PM
  3. vn accelerating PROBLEM
    By STYALR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2005, 10:16 PM
  4. Accelerating (RPM)
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 11:21 AM
  5. vibration when accelerating
    By vneom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 01:24 AM
