Results 1 to 4 of 4
Thread: Check Engine warning after new spark plugs and Mace engineering Manifold insluator
    Ve Omega S1
    May 2011
    Horningsea Park
    Default Check Engine warning after new spark plugs and Mace engineering Manifold insluator
    Hey
    Just recently i installed new sparks and a manifold insulator but im getting the check engine light.. The car sounds normal, it actually runs alot smoother and a deffinite torque increase.. It a stock ve Omega S1.. I'm not to sure if i have to go to a tuner to remove the error code or i did something wrong ???
    Has anyone had this problem....
    Ps, the spark plugs are NGK platinums and the space between the electrode and spark have been adjusted for the engine aswell...
    Back again only an hour later.. I started my car and i noticed on the dash the check engine light has turned off.. I Guess the ecu was just tuning itself for the extra air flow from insulator.. Correct me if im wrong.. Cheers.
    2012 S2 SV6 Sedan
    Apr 2010
    I know there were issues with TPS (throttle position sensors) when you removed the TB from the L98, LS2, to clean or do modifications, such as different intake manifolds.
    Note sure if its the same for the V6? It may have just needed to relearn. Monitor it and see how it goes other wise get it looked at..
    Phil
    If your not living life on the edge, then your taking up space!
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    you probably unplugged something while the ignition was on
    the code is "open circuit ****part**** "
    after three or so igntion cycles without the fault
    the code is stored as a history code and for some codes the light is then turned off
    like for... evap purge solenoid rh top of inlet manifold for e.g.
    dont worry about it unless the light comes back on~!
    VE SV6
    Feb 2011
    SE Suburbs Melbourne, Australia
    I installed the insulator last Friday and didn't have any problems apart from it idling at 1000revs at the start for 2mins, which is normal for cold conditions.
  1. the Vt V6 memcal from mace engineering
    By bennyboy91 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2011, 11:06 PM
  2. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  3. mace engineering cai
    By brendosv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-08-2010, 03:07 PM
  4. Removing Spark plugs V6 Engine - (VY model)
    By Sean880 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-12-2009, 03:52 PM
  5. [SA] 5L CAI (mace engineering)
    By 96SEN8R in forum Parts And Other Items For Sale
    Last Post: 23-01-2009, 01:11 PM
