Hi All,
Is it safe to unlock the rpm on my 2009 ve ss...I have a auto transmission with sports mode and triptronic as well BUT on all 3 modes the rpm never goes past 6, as a matter of fact it hangs on 6...ppl here get it unlocked from unofficial sources.
Is it safe or does leave a bad effect on the engine, although it does voids the cars warranty...lolllzz
Ali A. Sheikh
Why do you want to rev it past 6000 rpm
Originally Posted by garth
cuz sometimes i get into a drag race, i got beat up from a 2006 5.7 ltr ss the other day, and this is the cheapest upgrade i can do....lollllzzzz
Ali A. Sheikh
Your motor peaks power @ 5900rpm If you want more power get a tune, extractors, exhaust, OTR etc.
Yes, unlock it. Then you can feel really stupid when you're walking down the road picking up pieces of piston and rod that have made an inopportune exit from the block.
Originally Posted by Reaper:
Originally Posted by Jecs:
hahaaaaaaa.....dat was some funny replies i guesss....well ive seen 2 cars wid unlocked rpm's and they did make a difference especially when the gear shifts from 1st to 2nd da tyres burn out or roll a bit like it does in 1st gear...Also these 2 cars were 5.7 litres (2006 ss) and mine is 6.0 litres, even then i could not beat them...As per them they only unlocked the rpm and nothing else, maybe they were lying....
Anyways if it is that much risky then im not gonna do it....Thanx for da gr8 info ppl....
Ali A. Sheikh
if you replace the "d"with "th" you wont sound like so much of a bogan twit, although wanting to remove the factory rev limiter probably voids that comment......
I reckon your taking the piss..........![]()
Dont put this SH*T on You tube or nuthin ....
What you should do to beat them Ali is drill a hole in your intake manifold to suit some 1/4" clear plastic tube, run this from your manifold to inside your car(just use a 50mm hole saw to get in) buy a can of aerostart and as your about to drag start spraying it down the tube and this will give you a similar boost of power to NOS
LOL
may b if u juz paint da car red all da boiz wil be lik wow red is da fast color and u wil hav all da respect n never lose!
Seriously one of the electricians i used to work with did this to the snorkle on our work Diesel landcruisers (used to drag race them home, on a private mine road) cause the 2 cruisers used to do the same speed, but it made no difference, just stunk the cab out lol,
Please dont try this it was a joke and any of that start stuff is seriously flammable
i had a mate at school who plumbed up one of the washer bottle kits to spray extra fuel into the carby of his vk needless to say it didnt work
please adjust the settings on your sarcasim detector it will be needed
that wonderfull knocking sound will indicate that is all working well
does any1 here gets serious or just fool around ???
Ali A. Sheikh
So, if i change the stock air intake with a k&n or some other intake, how much difference will it make and does that effect the engine in a bad way or good way ? Dont mind if my questions sound dumb or amateur cuz im really new to these things...and this is my sporty car...
Ali A. Sheikh
well as my car is under warranty for another 30,000 km and i get it serviced every 5000 km from the dealer, mostly oil change and routine checkup, if i change anything it voids the warranty.....as far as air intake is concerned i can easily and quickly swap it with the original one before going to dealer for service but headers and cams e.t.c ...i cannot for now....
Ali A. Sheikh
Only voids warranty if the new part causes the fault. Quality aftermarket products, installed by a licensed workshop is lightyears safer than canning your rev-limiter. No dealership will warranty that!!!
he's from saudi arabia guys, cut him some slack. Dealers might be different over there too.
Kuzman's Supercharged SV6 - MACE TUNED
come on ppl...can we get over da rev-limiter joke now.....besides in saudi we dont have any dealer for after market upgrades or so....we bring them in from dubai and get it fitted from any local workshop, the dealers wont do that for you....yeah, that how it is here.
Ali A. Sheikh
