Results 1 to 8 of 8
Thread: Help to get 350rwkw ve ss series 2
    VE SS S2
    Feb 2011
    patterson lakes
    Default Help to get 350rwkw ve ss series 2
    Hi needing advice on what cam specs to use on a 6lt ve to get approx 340-350rwkw, I have a 1 3/4 full ss di fillipo exaust and a orrsom otr, 25% underpulley ,valve springs, 3.70 diff and a small comp cam 118/224 sorry don't know the lift.I got 294rwkw on mainline dyno. Also I really would like to avoid a high stall, I only drive the car on weekends and special occassions. Do I need head work etc, any advice would be greatly appreciated.
    RUF-60L's Avatar
    RUF-60L is offline Donating Member
    2008 VE SS
    Nov 2010
    charge it! simple hehe
    Quote Originally Posted by dingdong555 View Post
    Be careful not to hit yourself in the head whilst pulling
    My Ride, RUF60L
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    if u changed the cam to a 28/32 or a 32/34 u will get around 340 - 350rkw but i think a stall would be needed as there a decent cam
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VE SS II
    Apr 2009
    the VE series 2 (L77) has collapsible lifters to suit the DOD/AFM, yes even the manuals! (unlike series 1 where the manuals were L98 and autos L76)
    so you should definately replace them with something stronger if youre going to push it, i know someone whose lifters gave out at 330rwkw (series 2 manual),
    I was recommended to change lifters with ANY cam change on the series 2 by the workshop I went through...
    and yes Wog is correct, anything more than you have now will likely require a stall convertor
    why dont you try a retune with E85, easy 10-20rwkw there!
    VE SS S2
    Feb 2011
    patterson lakes
    thanks for the info , it is a L77 and i will get rid of all the dod, at this stage e85 is hard to get,on the first tune it had 312rwkw , but it was running 18.97 rich and nearly choked me to death, chose another tuner and he said the previous tuner had a disney dyno and also that he smelt the richness from a long way. he tuned it and it had better manners but i lost the power.
    Quote Originally Posted by tomholzy View Post
    f6
    Feb 2011
    I know a guy whos making the kinda power your after hes got the GMM perforance turbo killer cam its 237/242 @.050 . He was making in excess of 360rwkw. He has since got better higgans race heads and is making even more power. Thats on a manual.
    carless for now
    Feb 2007
    perth,Western Australia
    in an auto something in the mid high 230's duration and over 600 lift and heads should do it and a stall for sure
    VE SS ute @ SV8 daily
    Jun 2009
    Quote Originally Posted by sickooli View Post
    LOTS!!!!!!!!!!!
    239/347 comp cam, double springs milled and ported heads Fast 102 LSXR(ported) 102 nick williams t/b flycut pistons 65lb injectores twin ASE fuel pump and E85 fuel. and a big arse clutch to hold it.
    That is about 360 at the wheels on a mainline. In an auto you'll be pushing it. As stated a blower would get you there but N/A is the BEST!!!!!!!!!!
  1. series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2011, 11:49 AM
  2. Replies: 8
    Last Post: 18-03-2011, 05:34 PM
  3. VX Series 2 (Or onwards) Indicator & wiper stalks in VT Series 1 Calais?
    By Dimples25 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-03-2011, 05:56 PM
  4. 2.5'' Catback Exhaust, series 1 engine in series 2 body. [With out extractors]
    By Raremetal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2010, 05:46 PM
  5. wrecking VS CALAIS SERIES 2 INTERIOR + VS STATO SERIES 2 DOORTRIMS
    By petezor in forum Parts And Other Items For Sale
    Last Post: 07-05-2008, 10:50 PM
