What the deal ,?ok to drive until next tues until tuner gets his hands on it...Light didnt appear straight away,, after second short drive
Happened to me too after a few hours of driving after I pulled up at the lights.
The boys at VCM helped me out, took the car in for them to check if I messed the installation up, turned out the car was running a little lean on idle. They tweaked the mix, and all good.
Should be fine until your next tune.
did your light come and go.. Or just stay on from the first time
did u plug ur maf back in?, didnt leave anything out? i had the maf version on mine and no lights or nothing came up
yep everything put back ,,all i did today was get rid of dodgy breather set up and put flexi breather tube on..double checked everything before start up.Just curious wogboy how often you clean your filter
