Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Like Tree3Likes
Thread: VE Rear Diffuser
    VE II SV6 Sportwagon
    Sep 2005
    Default VE Rear Diffuser
    I was driving behind a SSV the other day that had the G8 style rear diffuser, and it didnt look half bad..
    considering getting one, though just a couple of questions..
    The ones on ebay say 'small' modifications are required to the rear bumper. anyone that has installed one know what these 'mods' are?
    And, do they fit the sportwagons? it say's it does, but not too sure.
    anyone with one installed on their sportwagon i would love to see some photos
    cheers, Troy
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Pontiac G8 GXP rear diffuser
    All you need to know...
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    VE MY10 SSV Sportwagon M6
    Jul 2010
    VE SSV 60th Ann
    Oct 2010
    I fitted one also. One question I have to ask though is that it says you have a SV6. Do you have quad outlets? I am just concerned it wont look very good with the basic SV6 exhust tips
    Also some advice after now fitting two. We find that its better to actually attack the rear bar a little with a dremel rather than simply modifying the tabs on the G8 version. You are meant to get rid of one of the tags if you read the 'how to' we simply dremeled a slot in the bar so you could use it. It's not like anybody would ever see it anyway.
    Sep 2005
    Well shit me! Thanks for directing me to that write up, didn't find it!
    Ye Ive got an sv6 with just the twin outlets, though why would it look strange with the g8 diffuser, the outlets don't change from the standard to the g8 do they?
    And I know this may seem abit stupid, but if you want to change back to the standard one later can you just swap them back over?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    he meant your exhuast tips.. it might look a bit funny.. whereas the ss has quad tips and they fill the gap abit more
    VE SSV 60th Ann
    Oct 2010
    Quote Originally Posted by Cameron P View Post
    he meant your exhuast tips.. it might look a bit funny.. whereass the ss has quad tips and they fill the gap abit more
    spot on.
    The SV6 had a single tip each side is all I meant. But the diffuser on the SV6 is the same as the SS so I understand wanting to change it.
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    put the diffuser on and if it looks weird that gives you an incentive to upgrade the exhaust system
    Sep 2005
    Yes but the cutout for the exhaust tips is exactly the same on the standard one on the sv6 and the SS, and that doesn't look funny, that was my point, that the standard one is the same on both SV6 and SS. So the g8 cut outs will be the same shit...
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    11' E3 R8 M6 Alto
    Sep 2005
    Quote Originally Posted by Troyziee View Post
    The G8 diffuser has a bigger gap compared to the standard sv6/ss/ssv diffuser.
    Sep 2005
    Ah k cheers mate,
    That's what I was getting at. I assumed the 'cutout' would be the same on the standard and G8 diffuser
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Ah k cheers mate,
    no which is why you were told it might look weird but as i said if it does just upgrade your exhaust
    Nikk_90's Avatar
    Nikk_90 is offline TINBUM
    VE SSV
    Jan 2011
    Rockhampton, QLD
  15. #15
    Sep 2005
  16. #16
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    I'm picking mine up tomorrow and should hopefully have it fitted over the weekend. There is a pic on here of a WM with one fitted but I can't remember where.
  17. #17
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Sep 2005
    I'm surprised they fit on a WM - didn't think they would since the rear bar is different!
  19. #19
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    I'm hoping it's not too hard to mod. If it is I'll end up finding someone on here who will buy it.
  20. #20
    VE Calais v 6.0
    Oct 2010
    victoria
    VE SSV 60th Ann
    Oct 2010
    Quote Originally Posted by Troy711 View Post
    It's not hard but is fidly. A dremel is your friend.
    As for fitting a calais, I don't believe so
  22. #22
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    VE SSV 60th Ann
    Oct 2010
    Yes I am surprised it fits the LWB as well. Based on that, maybe it does fit the Calais. My answer to that question was based on the Calais bar being different.
    As for fitting there is a good how to in the link above. But basically, the plastic tags that hold it to the rear bar are in different spots to the SS/SV6 one. You basically trim these. There is also a hole that needs to be drilled on the bottom. As I also mentioned above we decided not to completely remove one of thags and instead dremel a new slot in the rear bar
  24. #24
    VE Calais v 6.0
    Oct 2010
    victoria
    VE SSV 60th Ann
    Oct 2010
    Your local should be able to get them. Don't be fooled by pricing either. We have bought 6 now and paid $40 each for first two and then $55 for recent two
    Be warned. As this is a mod, the fit is not perfect (but good enough). Some of them start to sag. Hence why I have done it twice
  1. Pontiac G8 GXP rear diffuser
    By redvess in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-04-2012, 12:29 PM
  2. [NSW] GXP G8 Pontiac Rear Diffuser Commodore VE SS SSV
    By Prodrive in forum Parts And Other Items For Sale
    Last Post: 02-05-2010, 09:55 PM
  3. Whats the rear bumper/diffuser???
    By Shiny Alex in forum GMH Part Numbers
    Last Post: 27-03-2010, 10:36 PM
  4. GTS rear diffuser onto an SV6?
    By Shiny Alex in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-12-2009, 05:59 PM
