Results 1 to 10 of 10
Thread: Brand new car, Mineral or Synthetic engine oil?
    VE S2 SV6/A6
    Apr 2011
    Default Brand new car, Mineral or Synthetic engine oil?
    Newb to Holden question. I can't find this topic covered elsewhere.
    I am coming from a long term love with Subaru cars. Their factory recommendation is to only have mineral oil in the engine for the first 12,500 kms minimum.
    This is part of their running in process and they claim that synthetic oil will not allow their run in proceedure to occur correctly and the engine will take longer to loosen up.
    I always do a very early oil change on my new cars, typically within the first 500km and will then be doing 7500km changes thru the life of the car.
    Do Holden suggest Mineral or Synthetic as their runnning in oil?
    Current Ride: 2011 VE Sedan - In Voodoo of course.
    Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
    Also Own: 1964 EH Wagon, modified interior, minor modifications outside
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    If you put the motor under enough stress early on, the run-in process (for the motor at least) should be done and dusted by 500km. HSV, for instance, use Mobil 1 as factory fill - which is group 4 full synthetic oil. There's a few threads on running in new commodores on the site, have a flick through them to get an idea of what's required. Basically, don't baby it (obviously don't rev it through the roof either) but you want to put the motor under a reasonable amount of stress to bed everything in. Don't sit at highway speeds for extended periods and try and use all the gears. Just make the car work harder than average for the first 500 ish and you should be fine. The worst thing you can do is cruise in it straight up. If you're doing the oil change after 500, then so long as you've got everything bedded in properly, full synth will be fine. Make sure the filter gets filed in the bin as well and replaced with a newy.
    Holden have their first scheduled service at 3000km - if the piston rings aren't sealed properly by then, something is very wrong. When you take it in for this service, an oil change isn't part of it - make sure they do one! (and use the best oil you can afford at the time). You'll need a new filter and new oil - there shouldn't be much in the way of crap wearing off new motors any more due to better manufacturing processes - but I would definitely be changing oil then regardless. I would also then change it at 7500, then again at the 15,000 service - and every 7500 after that.
    VE SS II
    Apr 2009
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Quote Originally Posted by Voodoo_SV6 View Post
    LOL who fed you this garbage
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Quote Originally Posted by Cameron P View Post
    manufacturers do. Because they don't trust people to run their cars in properly.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    they might put mineral oil in from factory but from the first service onwards subaru use fully synthetic
    VE SSV
    May 2010
    Sorry not correct, Subaru use Semi synthetic and the first service is at 12500 kms.
    previously at 5000kms. will not use full synthetic unless you ask and pay for more.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    sorry semi synthetic..
    brand new liberty's and outback's dont have the 5,000km service but everything else does..
    VE S2 SV6/A6
    Apr 2011
    FAQs - Subaru Australia
    F.H.I. (Subaru Japan) have advised that they only require the engine oil used in Subaru vehicles to comply with the A.P.I. (American Petroleum Institute) classification for oil Quality and the S.A.E. (Society of Automotive Engineers) rating for oil viscosity as listed in your vehicle Owners Manual. F.H.I. do not differentiate between mineral and synthetic oils nor recommend a specific brand. Subaru Australia recommends staying with mineral engine oil until approximately 5000 to 6000kms to reduce the time and mileage taken to run in the engine. Synthetic oil generally produces less friction and therefore the engine run in time may be greater than mineral oil.
    The people who make the car - that's who.
    Although, they used to say minimum 12,500 many years ago
    VE S2 SV6/A6
    Apr 2011
    Quote Originally Posted by TinSnips View Post
    Thanks for the info, I am up to speed with some peoples preferred run in process and I stick pretty much to what you have suggested.
    Last Subaru and Falcon I changed oils on in the first few hundred kms had noticable metal particles in the removed oil. Yes oil filter is a must every change, or it's pretty pointless.
    I was more wondering about mineral or synthetic, sounds like I will leave it till I have had it a week then change it to fully synthetic which is good as I have no mineral oil in the right grade, but have over 50 litres of synthetic in the shed
  1. Changing from mineral oil to synthetic?
    By Freddie5.7 in forum General
    Last Post: 11-04-2010, 03:05 PM
  2. Synthetic ATF
    By chrisdoesitbetter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2010, 04:26 PM
  3. Mineral to Synthetic.
    By VYMAD in forum General
    Last Post: 31-12-2009, 06:09 PM
  4. Removing Synthetic Polish needed for non Synthetic Polish?
    By Chirpstr in forum Car Care Products
    Last Post: 30-07-2009, 08:20 PM
  5. Which oil? - Synthetic vs mineral...
    By matty193 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2006, 05:54 AM
