Results 1 to 15 of 15
Thread: Ve SS sedan 2008 tailshaft upgrade?
    VE SS 6.0L
    Feb 2010
    Unhappy Ve SS sedan 2008 tailshaft upgrade?
    Hey guys I was wondering if you know of anywhere that's got some decent tailshafts that can handle a bit more power than the stock one. Seems I managed to break mine with only a few minor mods (exhaust, Otr and tune) Holden wanna charge me nearly a grand for a standard one. So I figure I may aswell upgrade if it's only gonna happen again
    VE SS 6.0L
    Feb 2010
    VE II SV6 - Alto Grey
    Apr 2011
    Should be able to get a tail shaft custom made for you for around $500. Try Spicers...
    VE SSV 60th Ann
    Oct 2010
    I'm having this argument as well. Although I did fork out $1300 only to find nothing wrong with it.
    Consider this. If you buy a HSV and send it Walkinshaw, they can add superchargers and all the rest of their goodies. Do they upgrade the tailshaft when doing so. No. The reason "because you don't need to" - straight from Walkinshaw. If you broke yours with those mods (apart from cam similar to mine) then it should be a warranty issue. God the clutch is rated at 500hp so I don't see why the tailshaft wouldn't be engineered above the factory kw.
    I have a mate with a 800hp VE and he is the only one I know with an aftermarket tailshaft.
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    You broke your tailshaft?
    bahahaha
    I doubt it...
    There are 600rwkw cars thrashing around, with stock tailshafts...
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by EraserHead View Post
    2nd that. I believe Hardy spicers can do up upgraded tailshafts for VE's. The problem with the Std VE commodore ones is theyre made so that individual worn components cant be replaced easily so that even if you have a worn uni joint they'll try and sell you a new shaft for a grand.
    Where did the standard shaft break?
    VE SSV 60th Ann
    Oct 2010
    On mine there is nothing wrong with the one they replaced. It has turned into a legal battle. They say my car produces too much HP (412rwhp) and that's why it broke. But it didn't break..... Hence why I have spoken to Walkinshaw etc
    VE SS 6.0L
    Feb 2010
    Quote Originally Posted by HoZy View Post
    bahahaha
    I doubt it...
    Well mate if you were te one that pulled the shaft out and looked at it you'd find that the front half rattles around and frequently locks up .. So I reckon you'd come to the same conclusion
    VE SS 6.0L
    Feb 2010
    Quote Originally Posted by monkeys437 View Post
    It's gone in the slip join just before the centre bearing.. Rattles like crazy and locks up at low speeds
    VE SS 6.0L
    Feb 2010
    Quote Originally Posted by bonners View Post
    Fair enough .. I would claim mine under warrenty but that ran out 2 weeks ago and they dont want anything to do with it .. Unless I wanna pay for a new shaft through them
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    try another dealership or ring customer assistance - 2 weeks out should be good for at least a partial coverage.
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by drag_matt View Post
    Thought that might be the case. Is it a manual? This is a fairly common issue thats just starting to appear and seems far more prevalent in the Manual models. The issue isn't the power going through it as the slip joint is a rolled spline, and can handle a shitload of torque. The slip joint only gets greased once when the shaft is made and doesnt seem to retain lubrication very well causing it to wear out
    VE SSV 60th Ann
    Oct 2010
    This is what appeared to be the case with mine. The dealer replaced it quoting it was foobarred but a diff mechanic opened it up and found it wasn't lubricated. He then lubricated it and found it to be fine. Hence my battle
    VE SS 6.0L
    Feb 2010
    Yeah it is manual .. If they don't hold their lubrication very well is it possible to fit a grease nipple to the shaft?? I havent even looked to see if it's possible yet as I haven't pulled mine apart.
    Also does anyone have the measurements of the shaft?? Is there a difference in length between the v6 and v8 shafts or are they the same?
  15. #15
    VE SSV 60th Ann
    Oct 2010
    Can I ask exactly what it is you do for a crust? PM me if you like. I'd love to ask you some more questions about this
  1. wagon vs sedan v8 tailshaft
    By aussie_macca in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-05-2011, 10:09 PM
  2. sedan tailshaft to wagon?
    By jatsvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-10-2008, 07:59 AM
  3. Forum Upgrade 23-8-2008 - Completed
    By Darren in forum Site Feedback / Site Problems
    Last Post: 26-08-2008, 04:56 PM
  4. WTB: VN/VP/VR/VS Manual tailshaft for sedan
    By dans_vz in forum Swap / Wanted to Buy / Trade
    Last Post: 06-03-2008, 04:00 PM
  5. VS Sedan reconditioned tailshaft
    By Bud in forum Parts And Other Items For Sale
    Last Post: 14-07-2006, 10:45 PM
