Results 1 to 24 of 24
Thread: Difference in ve ss exhaust between manual and auto with afm??
    Series II SS
    Jul 2010
    Default Difference in ve ss exhaust between manual and auto with afm??
    Hi guys,
    Just a quick one. Is the standard exhaust system(from the cats back) the same for both the manual and auto(AFM) VE SS, or is there some sort of difference?
    Also mine is a Series 2,
    thanks in advance
    IF YOU BUILD IT THEY WILL COME.... STILL WAITING LOL
    Ve SSV
    Apr 2010
    Melbourne SE
    I dont think there is any reason why it wouldnt be all the same, the only difference is the AFM on the auto
    SSV Redline Ute (Voodoo)
    Apr 2011
    Liverpool
    2012 S2 SV6 Sedan
    Apr 2010
    There was a differnce in the rear mufflers, intermediate and headers when they were using L76 for Auto's (car equiped with AFM) and the Manual's which had the L98. Now I believe they are all the same at from front to rear.
    Basically the AFM cars had flex joint at the rear of the intermediate just before the rear muffler bolted up and the rear muffler was a single outlet Y piece with chrome tips for the quad look. At the header end, then engine pipe (connecting to the cat) was slightly shortend to accommodate another flex joint.
    On the manual there were no flex joints (either end) and the rear mufflers had a true dual pipe outlet. Can post pics if you need them...
    Phil
    If your not living life on the edge, then your taking up space!
    Series II SS
    Jul 2010
    Sweet, thanks guys, unfourtunetly im having to put a stock system back on, dam AFM driving me insane with modded exh.
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    RUF-60L's Avatar
    RUF-60L is offline Donating Member
    2008 VE SS
    Nov 2010
    Quote Originally Posted by TinSnips View Post
    nooooo... say goodbye to the AFM instead!
    ^ this. get an otr and a tune and there wont be much difference
    Quote Originally Posted by dingdong555 View Post
    Be careful not to hit yourself in the head whilst pulling
    My Ride, RUF60L
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Quote Originally Posted by SYC05S View Post
    yes there will... it will be better!
    RUF-60L's Avatar
    2008 VE SS
    Nov 2010
    well yes, louder and more powerful is always better
    My Ride, RUF60L
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Series II SS
    Jul 2010
    Lol that was an option before the lifters decided to start tap tap tapping, so cant really afford to risk warranty atm
    RUF-60L's Avatar
    2008 VE SS
    Nov 2010
    anyways back to topic....dont put the stock exhaust back on, if u changed it u obviously want to hear it, so if u have to turn the AFM off, do so
    edit: just read ur latest post, ok wait til fixed, keep the exhaust stored til ur confident its fixed, then put it back on! anyways, i dont think it would void warranty, if the exhaust caused the problem then it would be void...
    My Ride, RUF60L
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Could you not just keep the gearbox in manual shift mode until everything is sorted? Should stop AFM from kicking in.
    RUF-60L's Avatar
    2008 VE SS
    Nov 2010
    also this ^ im pretty sure i said that in ur car's thread not that long ago :P
    My Ride, RUF60L
  15. #15
    Series II SS
    Jul 2010
    I dont know if its made this way but in my manual mode it still kicks in if in 3rd, 4th or 6th gear, not 5th???? Not as often of course but it still does.
    I was on the M7 last wknd and neither manual 6th or Drive was any good at all, virtually vibrating along...
  16. #16
    RUF-60L's Avatar
    2008 VE SS
    Nov 2010
    ewww thats lame, shut it off...i dont think it would void warranty, i think u can even ask holden to do it.
    wouldnt hurt to ask
    My Ride, RUF60L
  17. #17
    VE SSV SE 2010
    Apr 2010
  18. #18
    RUF-60L's Avatar
    2008 VE SS
    Nov 2010
    yay! go me! :P
    My Ride, RUF60L
  19. #19
    Sv6II Ute
    May 2011
    Hey Guys,
    First Time Poster, Long Time Troll!
    Look I signed up for info for My VE II SV6 Ute, Manual
    I have always wanted to change the factory exhaust, but for looks only, pretty happy with the sound level, a deeper growl i wouldn't mind, but not a volume big increase, I definitely do not want a drone!
    Ive decided to go out and get a SSV Rear mufflers, suit my application perfect,
    If i could choose any, wich one would be best?
    VE SSV AFM (Y Pipe after the muffler)
    VE Non AFM (One in two directly out)
    From what i've read and gatherd... a SSV exhaust NON AFM will enhance the growl, a lil bit, but mild drone,
    SSV AFM Will sound exactly the same?...
    Is there any difference between HSV rear mufflers and SSV Mufflers?
    Would they be different again?
    Thanks
  20. #20
    Sv6II Ute
    May 2011
    Hey Guys,
    Long Time Troll First Time Poster....
    For a Manual SV6 Ute
    If you had a choice of Non AFM SSV Mufflers
    Or
    SSV AFM Y Pipe Muffler
    To Upgrade to dual pipes wat would you choose?
    Thanks
  21. #21
    Commodore
    Jun 2004
    NSW
    Quote Originally Posted by BRE77W View Post
    Hey Guys,
    Or
    Thanks
    i had both on my sv6
    non afm droned like crazy under load and were quite loud for factory muffler so I got rid of them
    afm mufflers almost as standard...no drone and slightly louder than stock
    i know what i would do if i was you
  22. #22
    2012 S2 SV6 Sedan
    Apr 2010
    It depends on which HSV mufflers you choose. The "standard" are the same as an SS with the single in and true twin pipe out, only difference is the HSV have billet tips and the SS has chrome (which I think look more impressive). The HSV exhaust option (also depending on HSV model if option or standard) which is a Bi-Model exhaust (rear muffler) which is kinda like a varex system. Those mufflers are louder than the others.
    I was at my local dealer last night in the workshop and my mate was preparing a brand new off the showroom floor yellow E3 GTS to take to Walkenshaw for fitting of the supercharger. When they drove in I asked what exhaust it had because it sounded nuts. It was factory standard and growled its head off... But at abotu 1,500rpm the Bi-Model system kicks in to quieten it down. You can fit the whole HSV system to the car with those mufflers (just that you can connect up the rear muffler solenoids) so it should sound pretty loud with out being to agressive.
    I don't know what it would be like on an SV6 but on an SS V8 it would be interesting to hear...
  23. #23
    Sv6II Ute
    May 2011
    Thanks for the info guys,
    Yea HSV system sound pretty good, over kill for a 6,
    AFM Vs non AFM
    Man i kinda wanna get Non AFM and see what its like then if i don't like then get AFM Y Pipe,
    2010 CalaisV Sportwagon V8 Auto
    Mar 2004
    mine did this also.
    the way to get around it is when you get on the highway switch to manual mode, knock it back to 5th wait for about 30 seconds then knock it into 6th, should keep AFM off then!
    and you can drive around shifting manually and the AFM wont kick back in until you swtich back to [D]rive
    Also, on the Drone problems, i am Dynamatting & Dynapad my wagon this weekend, will let you know if it makes much difference
  1. VT auto/manual difference.
    By Erictheinstro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2010, 02:58 PM
  2. manual exhaust on auto?
    By kelman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2010, 11:48 PM
  3. Difference between auto and manual engine loom ?
    By 85commolux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2009, 02:26 PM
  4. Manual&Auto Starter Motor Whats the difference?
    By V-ahhh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2009, 10:28 PM
  5. difference between s1 auto and s1 manual
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 07:47 AM
