Results 1 to 17 of 17
Like Tree3Likes
  • 1 Post By a.critta
  • 1 Post By SteveHatz
  • 1 Post By sv6 power
Thread: VE SV6 Centre Speaker
    VE SV6 Series II
    Jan 2011
    VIC
    Smile VE SV6 Centre Speaker
    Finally removed my centre speaker from my SV6.. sounds sooo much better now!! (No more vibrating!!)
    Felt like i was gonna break something while i was doing it but all worked out fine
    Now just need to put a decent sound system haha
    Verdict.. Anyone who does have a centre speaker.. make sure you take it out!!
    VE Omega
    Jul 2010
    FINALLY!
    shouldn't you be studying for exams though :P haha
    forget about sound system for now
    RIMS & LOWER!!!!
    07 VE SV6 COMMODORE
    Apr 2011
    Australia New South Whales 2428
    I was considering moving the centre speaker myself, is it as easy as poppin the cover off n unscrewin it n choppin the wires?
    HUX 90's Avatar
    HUX 90 is offline POSION VE SS UTE
    09 VE SS UTE
    Mar 2011
    07 VE SV6 COMMODORE
    Apr 2011
    How much they worth HUX? i just pulled out the centre speaker, sounds much nicer already!
    VE SV6 Series II
    Jan 2011
    VIC
    haha i know steve tell me about it.. naa i had to take a break!! :P
    yeah dw rims and lowering is defs on the list.. just waiting for the right ones
    im feeling a tune pretty soon though.. engine light has finally come on and its starting to do my head in haha (good excuse to get it done :P )
    VE SV6 Series II
    Jan 2011
    VIC
    glad to hear it sciacca!
    yeah HUX did it make much of a difference with the polk 4"?? does it vibrate at all??
    2012 S2 SV6 Sedan
    Apr 2010
    I left mine in there but disconnected it from the sound system. I use for my communication gear thats in the car.. I would like to fit a better quality one but cant get one small enough to sit properly without having to make a spacer.
    If your not living life on the edge, then your taking up space!
    HUX 90's Avatar
    09 VE SS UTE
    Mar 2011
    I think you can get 2 for about $100. I got an installer to supply the speaker and he wraped the mounting plate with foam so it doesn't vibrate and he soldered wires and terminals to it so it could just plug it in. If you have a dual voice coil set up a single voice speaker is fine I just used the positive from 1 channel and the negative from the other channel. Depending what way you wire the speaker up will affect how powerful it is in a dual voice coil set up. It's made a huge difference, there a photos of it installed in my album on my profile. 4" Speakers are a bit of a tight fit to get in so be patient.
    VE SV6
    Feb 2011
    SE Suburbs Melbourne, Australia
    Yesterday (Sunday), i finally had some spare time to disconnect the center speaker, but the thing was that i didn't have a small screw driver so it won't hit the window, so i had to take off the head of the screw driver and use my strength to unscrew the screws, surprisingly they were easy to take out. But the thing was, after i took out the 2nd screw my cross screw driver head fell in where the hole was of the speaker (grrrrrrr). in the end i had to do exactly what that dude did on tv from supercheap auto with the rattling.
    Took me 3 hours to slowly take all the parts off the whole dash board...... The end result was that it fell so far back that i couldn't reach it.... even more back than the audio head unit. So i gave up in the end and put the car together.
    I drove down a street doing 60km/h and at the lights pressed brake, at that moment i heard the little metal screw driver head fall down from where it was and ended up on the passenger side ( i had forgotten to put the plastic back from that side).
    Out of frustration all i could do is laugh.
    2010 SV6 Voodoo Ute
    Jul 2010
    Can someone just confirm for me that if you disconnect the centre speaker the bluetooth phone audio still works? Mate with an '08 SV6 believes his bluetooth audio no longer works after he disconnected it. To me its sounds like the phones's audio comes from the right main door speaker?
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    one million per cent certain it works. Have done it to mine.
    He needs to adjust the balance setting while on a call to driver's side front - that will make the phone audio come from right next to him, which puts less stress on the noise reduction bits of the bluetooth module.
    2010 ve sv6 Ute
    Feb 2010
    I haven't removed my centre speaker but when I use the Bluetooth I can hear the person on the other side of the call but they can't hear me. Any suggestions would be appreciated. Sry to hijack
    VE SV6 Sedan
    Jun 2011
    brisbane
    I just cut the wires to mine n whacked a sound system threw the rest... Ohhh how I rememmber how horrible it sounded
    07 VE SV6
    Mods: K&N high flow air filter in box, x-force 2.25" cat back system
    Sound System: Alpine type r fronts and rears, 2x Alpine type r 12" sub, Boss audio 1500 watt mono Amp, Kicker 450.1 Amp
  15. #15
    VE SV6 SERIES 2
    Jun 2011
    Kearns
    Sorry to bring this thread up again guys but I have a problem. Has anyone with a series 2 taken the centre speaker cover off easily? I can get the back 2 clips to pop up but the ones at the front won't budge and I don't want to break anything. Seems like if I pull any harder it may snap clean off.
  16. #16
    VE BERLINA 07
    Jan 2011
    Rowville Melbourne Vicotria
    Quote Originally Posted by Global Xpress View Post
    omega dont have a centre speaker and it still work has nothin to do with it mayb if he has disconnected it he accidently discconected a wire from the bluetooth module bcoz its around the back off the head unit
    I'm a boy who appreciates a good body, regardless of the make.
  17. #17
    VE BERLINA 07
    Jan 2011
    Quote Originally Posted by rum87 View Post
    the front roof lights have the mics in there mayb get that changed
  1. How to: Remove VE centre dash speaker
    By TehFastyOne in forum Car Audio
    Last Post: 17-05-2012, 12:26 PM
  2. Centre dash speaker in VE
    By stitchvessv in forum Car Audio
    Last Post: 24-12-2011, 07:36 PM
  3. VE Centre Speaker Questions
    By neevo in forum Car Audio
    Last Post: 29-12-2009, 06:47 AM
  4. VE SS-V Centre Speaker
    By macca_223 in forum Car Audio
    Last Post: 28-04-2009, 06:04 PM
