Just found some moisture in my VE indicator. (The small one on the side of the car, above the wheel well.)
How does one remove it?
Gently grab the indicator and slowly push forward, the back of the indicator will then be free and it can be removed. All of 5 seconds work. Just do the opposite to put it back it.
If you remove the bulb, don't drop the wiring back down into the body...............
Front wheel drive cars are the work of the Devil.
