Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Like Tree33Likes
Thread: Real silly silly question... but gotta ask it.
    2011 SV6
    Apr 2011
    Default Real silly silly question... but gotta ask it.
    Real dumb i know, but how the crap do I engage reverse in my manual SV6?
    Got it, love it even if they 'forgot' to order the DVD and tint... but can't put it in reverse
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Ok my first reaction is What....The....####??????
    Just put it in?????
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VE SV6 ute
    Apr 2009
    vic
    when it's in neutral, push it as far left as you can then up!!! If that doesn't work something must be farked
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Use the force.
    Or failing that use the clutch and the shifter.
    Ronald Reagan (1986)
    2011 SV6
    Apr 2011
    No, not that simple. It doesn't have a pull up lever to engage reverse, nor does it push down to engage reverse
    VX Berlina
    Apr 2007
    What? Lever?
    Move the shifter all the way left, than up, while holding down the clutch.
    2011 SV6
    Apr 2011
    In the courtesy cruze i got and most euopean cars i've had theres a small ring you pull up and engage reverse.. the SV6 doesn't have this.
    VE SV6 ute
    Apr 2009
    vic
    VE SS II
    Apr 2009
    theres no fancy way of 'engaging' it like in other cars with a lift up or push down,
    the gate for reverse is a little harder than for 1st, so when you want 1st you push it gently left and when you want reverse you push it harder, you will feel it when you do it right dont worry youll get used to it
    2011 SV6
    Apr 2011
    VE SSV SE 2010
    Apr 2010
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Ordered a manual...but cant drive manual. What a fool.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VS Stato l67
    Mar 2009
    Melb
    It sounds like you gearbox is a bit stiff. You might have the model fitted with a stage 14 cop shift chip. It cancels out most Sinusoidal Phase Detractions but It can make shifting into reverse a bit difficult.
    When mine gets a bit stiff I just grip it a bit tighter and force it to go where its meant to. The same principle can be applied for changing gears
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    All I do is put it in neutral and rev like bam bam bam bam bam bam and then select D for maximum respect
    clicky if you don't recognisey.
  15. #15
    MY9.5 VE SV6
    Jan 2010
    south east melbourne
    all u have to do is in neutral push it to the left QUICKLY. from there push it upwards and reverse is engaged. when in neutral if move the gearstick slowly you can only lock it into first gear. hope this helps.
    __________________________________________________ _______________________________
    PHANTOM MY 9.5 SV6 manual
    anyone know where i can get cheap rim and tyre packages?!
  16. #16
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    I know what he's talking about - in a lot of cars, (including korean holdens) you need to pull a ring or a clip upwards to engage reverse - or even the whole shifter in some cases.
    Nothing like that on a commodore - you push it past the 1/2 gate (v6 - v8s are past 5/6 gate) - there will be a notch there and push forward as if engaging first, but a gate further over. You won't be able to select it if you're moving.
  17. #17
    Mike08's Avatar
    Mike08 is offline No Back seat drivers
    VE SS Ute
    Feb 2009
    Queensland
    Have you turned the actual key on ? , my SS will not entertain reverse without it turned on all the way.
    Failing that , you maybe should have bought an auto.
    Cheers.
    Mike
  18. #18
    2011 SV6
    Apr 2011
    Funny bugger
    Car was on an incline so may have been rolling back. Come back to a manual after having a DSG Passat / Manual Audi Quattro Turbo and a Holden Cruze.
    Will have a play, hopefully am not so retarted... again.
    Quote Originally Posted by Mike08 View Post
    Cheers.
  19. #19
    1999 VT
    May 2011
    queensland
    Quote Originally Posted by Darks View Post
    that should make it easier then
  20. #20
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    In most Automatic cars you just pull the lever straight back 1 click and it goes into reverse. Also to put my forklift in revers you pull the green lever towards you. These and many other examples also have zero relevance to an SV6 too.
    Up and left. As Sab said - why buy a manual if you can't drive one?
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  21. #21
    2007 VE Lumina
    Apr 2011
    not so retarted
    retarted
    Oh sweet Lord, he HAS to be trolling.
  22. #22
    Luke V8's Avatar
    Luke V8 is offline AKA Luke!
    VE Commodore SSV
    Feb 2011
    You put your left foot down, your gear stick left, your gear stick up and you shake it all about... you do the hokey pokey and you move it around, thats what its all about...
    all together now...
  23. #23
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    You signed off on delivery without checking if car went in reverse ok?
    Just curious, which dealer in Canberra did you buy the car from?
    Any chance it was Phillip?
  24. #24
    VE SSV Series II Sedan
    Feb 2011
    SA
    Right... We need to take the car off of him... Its that simple.
    Holden Commodore 2010 VE Series II SSV Sedan - Voodoo Blue: Icey's SSV
    My other little toy: Car Camera Recorder
  25. #25
    2011 SV6
    Apr 2011
    All sorted. What I meant by using other cars as an example was the fact it was a no brainer putting it in reverse. The sv6 is a bit stranger. Car is a manual and not automatic.
    Car was bought from comm motors tuggeranong, and I paid more attention to th fact that I ordered the fold down DVD and didn't get it, this argument was taking place while he was showing me the rear camera and nav. Ordered plates hadn't come in, so that also made me miss the reverse quirk. Thanks for the helpful cOmments.
  1. silly question?????maybe
    By BVL87 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-03-2011, 08:43 AM
  2. silly question,,, what does bcm mean
    By jayvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2010, 03:20 PM
  3. Silly Question
    By aw006 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2006, 10:54 PM
  4. Silly question but....
    By Macca177 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2005, 02:07 PM
  5. Silly question
    By vpgirl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2005, 02:07 PM
