Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Luke V8
Thread: VE SSV - AMP Control
    Luke V8's Avatar
    Luke V8 is offline AKA Luke!
    VE Commodore SSV
    Feb 2011
    Default VE SSV - AMP Control
    Hi All,
    Think i may of seen it posted before but just incase...
    If you want to increase the bass in your "premium" () sound system then behind the battery to the side is the amp control.
    Just pull down your boot lining, and in mine, the amp nob is at the bottom, so reach down and across and you'll feel it. It always clicks back to the middle so don't worry that you can't see it.
    Have fun
    SSV Redline is offline You Ride I Ride
    VE Series II SSV Redline Sportwagon
    Mar 2011
    Thanks man, will give that a tweak tonight. I ended up lining everything with dynamat and and mounting a pre-amp with mid and bass boost inder the dash. The system does doof at 148db like the one I heard a couple of weeks ago but it certainly has given me some bass boost for that 70's classic rock I love so much.
    VE SSV SE 2010
    Apr 2010
    I find adjusting the bass to +2 or more in the EQ is overkill and sounds crap. Does this improve the SQ or just make it louder?
    VE SSV Series II Sedan
    Feb 2011
    SA
    Thanks, Will give it a shot when/if i get my car back.
    Holden Commodore 2010 VE Series II SSV Sedan - Voodoo Blue: Icey's SSV
    My other little toy: Car Camera Recorder
    2012 S2 SV6 Sedan
    Apr 2010
    Here's a photo. The gain control is a bugger to access. Might be easier to undo the screws holding the unit in place and take it out.
    This is off the top of my head so i may miss a step:
    1. take the floor out of boot.
    2. the panel where the boot lock is there is a couple of cargo net hooks there...unscrew then and it literally lifts out...its just clips
    3. then on the left side where the battery is there are some colour coded plugs/clips pull them out by getting either the two pronge fork shape tool or a flat blade screw driver between the carpet and clip and pry it off...
    4. peel back the side panel carpet and now its the fun task of crawling in and turning the gains up
    Picture courtesy of another forum.
    If your not living life on the edge, then your taking up space!
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Good pic! You prob don't need to go to that extent (i didn't)but if you have hands like shovels (i dont!) then you prob will!
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Quote Originally Posted by SSV Redline View Post
    How'd ya go dude
    VE II SSV Sportwagon
    May 2005
    top of Sydney basin
    I read about this ages ago and told a mate. He tried it and could hear any difference!
    Is there a amp in the SSV series 2 wagons??
    VE II SS-V Sportwagon
  1. VR V6 93 Acclaim heater control / climate control switch
    By tom slick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2011, 02:26 AM
  2. [VR-VS] How to change Heater Control globes (NON climate control)
    By Fonzie in forum Holden Commodore How-To's
    Last Post: 03-08-2009, 11:28 PM
  3. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
  4. trac control button and heater control lights!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2008, 09:07 PM
  5. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
