I have VE berlina with 19" SSV series 2 wheels. Does anyone know if it is possible to lower stock standard suspension by about 2 inches without having to buy new suspension. Can this be done easily?
Cheers.
buy new springs
Current project VH SL SEDAN 202
http://forums.justcommodores.com.au/...-83-vh-sl.html
Last project VH SL WAGON L67
http://forums.justcommodores.com.au/...h-wagooon.html
Yeah dude, it's piss easy.
Just get your hands on an Oxy-Acetylene torch and give them the once over.
Not too much on each one, or they might sag.
if you know what you're doing easiest/cheapest method would be to cut them. But you will probably #### it up. For the price of springs $200 a set might be better? Upto you
Kuzman's Supercharged SV6 - MACE TUNED
also if you cut them any insurance you have on the car will be void cause chopped springs aren't road worthy ... so just buy new springs ... generally at wholesale suspension or pedders or something like that its about 550 for all four installed with a wheel alignment ... or i got springs and shocks (king Springs and munroe shocks) on ebay brand new for 690 and i got them installed cheap ... i have done just springs and springs and shocks and for two inches the ride quality will be way better if you buy shocks and springs ... cause if you lower it too much on the standard shocks they get too hard and choppy but its up to you
anybody suggesting to cut springs has no brain !
About 500kg of railway ballast or bricks oughta do it. And yeah, it's real easy. Herp.
Just get springs.... If you wanna do it on the cheap dont worry about shocks.... My car is on ultra lows with the standard shocks & its absolutly fine
I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
I dont know how you would chop springs in a VE as the rear springs are tapered
If you've got some fat mates, just ask them if they'd be willing to come with you where ever you go, will look tough as and will probably impress the ladies when they look inside the windows at old mate licking on an ice cream, unless you're like me and don't like people having food in your car...
buy new springs or have yours compressed .
If you can afford a VE Berlina, you can afford to lower correctly and safely.
Think of you fellow motorists on the road.
Do it the correct way mate, and not only will it be safe but it will keep your ride heading in a safe direction.
Cheers.
Mike
Took longer then I thought for someone to point out the tapered springs. My first car (vn) had cut springs in it when I bought it, they lasted the drive home til they were replaced. Not worth the risk but in a ve you could only do the fronts and the effort required to do it just to save a few dollars isn't worth it, just buy some kings off ebay
Okay I will get some new springs. Just the low the ones. Is it essential to get the shocks changed as well?
Joey, nah you can just do springs if you aren't going too low, but shocks will help.
just for your knowledge joey, as far as king springs go i'm pretty sure that "SL" or "low" is FE2 hight ie sv6/ss/ssv hight, "SSL" or "super low" is one inch lower than FE2, and "SSSL" or "Ultra Low" is 2 inches lower than FE2 ... just for you to have some idea ... That is what i have worked it out to be ... please correct me if im wrong anybody.
if you go with SL or SSL than you should be fine to keep the standard shocks i reckon
but if you go kings, just tell them your required hub to guard measurement. they will then tell you the springs you will need to achieve that height.
I also make Electronic Dance Music
http://www.youtube.com/user/klampykixx?feature=mhee
yeah thats the easiest way
Thanks Astroham.
I am thinking of going the super low king springs front and rear tomorrow. Would anyone have a picture of a VE with super lows front and rear on 19 inch wheels.
Thanks everyone for your advice.
I lowered mine, just with springs first. I've since added lowered shocks and it's heaps better, well worth the extra $$$
Hi Guys,
I got the King Springs super low and the car looks great and drives well.
