Results 1 to 10 of 10
Thread: Rear Subframe Bushes
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    Default Rear Subframe Bushes
    Hey, as i understand it the VE's have a voided rear subframe bush and from most suspension shops you can buy a void filler for these ...
    Now my question is, Has anybody Done this? Did it noticably improve your ride? How much did it cost? Was it worth the cost?
    VE SSV 60th Ann
    Oct 2010
    I had the void bushes put in after I had the coilovers done.
    I had the coilovers done and it transformed the car. Was told to go back after 1000k's to check tightening etc. It was here that I di the bushes. It transformed the car again. It felt like rear was nice and firm and well planted.
    Think it cost me $250 fitted
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    VE SV6
    Apr 2009
    After i had them put in the first thing i noticed was the rear end did not bounce around anywhere near as much. Makes for a much better ride. The rear end is firmer. Im happy i got it done.
    Had other stuff done when i had these fitted but think it was around $300 for them fitted.
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    I had them installed and Tommos comments are pretty much the same as mine. I also had a heap of other stuff done at the same time so I can't comment on just the rear. Check my ride thread for more details (link below).
    SIDI sv6
    Jan 2010
    Penrith
    bladerunner's Avatar
    bladerunner is offline AUSTRALIAN MADE AND OWNED
    VE SS UTE
    Nov 2010
    brisbane nth
    yeah im looking at doing the same. do they stop axle tramp?
    im out of my mind at the moment...please leave a message
    11' E3 R8 M6 Alto
    Sep 2005
    Quote Originally Posted by bladerunner View Post
    They dont stop it 100% but they do help alot in reducing it.
    MY08.5 SV6
    Aug 2005
    Loganholme, QLD
    I've had the Nolathane set of bushes sitting around my garage for about 6 months, I have been putting it off and off for ages. Having a steep driveway isn't helping anyone done it themselves and time estimates?
    If it helps i plan on lowering my SV6 myself so is it worth waiting untill i do that?
    Im a true commy boy!!!
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    MY08.5 SV6
    Aug 2005
    Loganholme, QLD
    Cheers troy, i had a think about it. It seems that it'd be best to lower it than put it all back together and start from scratch so everything is back where it should be before i start. I was told by Red Ranger a bloke i used to work with actually that it's probably a days work. Either way i will have a stab.
  1. Rear cradle subframe mount?
    By thekow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2010, 05:58 PM
  2. Changing the rear subframe/k frame YAY!
    By CommodoreAdict in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2010, 02:28 PM
  3. Wanting to fit VR-VS rear subframe into VP IRS
    By vp_exec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2010, 05:53 PM
  4. Caster bar bushes and rear cross member bushes
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2008, 08:32 PM
  5. Cracked rear subframe
    By toolbox1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2005, 11:33 AM
