Results 1 to 24 of 24
Thread: has anyone had this happen to there radio clock display
    SV6.07's Avatar
    SV6.07 is offline Enjoy it Drive a Holden
    2007 VE SV6 Nitrate & 2011 VE SV6 Poison Ivy
    Oct 2010
    Melbourne,Victoria
    Default has anyone had this happen to there radio clock display
    got into car this morning. started car. and the entire display where the radio is off. no clock nothing just black.. radio still worked . just no display at all.. ok it was really cold this morning outside temp was showing 1c and ice all over car windows. but strange for the display to go out. drove for a min and it came back on. never done this before since having the car. now had it for 3 years. the other parts of the center console was all on heater controls all lit up but just the display was out.. anyone else had this don't know if there is a plug to check or what powers that display area... can anyone help on this strange problem.
    many thanks to you all.
    VE SV6 Sportswagon
    Apr 2011
    I have a 2009 sv6 and I had the same problem a couple of months ago. Had to switch the car off and back on to make it work again.
    SV6.07's Avatar
    Oct 2010
    Melbourne,Victoria
    Dangerous Dave is offline Donating Member
    VS Berlina
    Mar 2009
    something perhaps to do with the fact they are an LCD, or LIQUID crystal display... And if it was that cold....
    VE SV6 Sportswagon
    Apr 2011
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    i wonder if its only common to SV6 owners? never happened to me, but then I dont have an SV6 either.
    interesting that it came back on by itself later on, because if it was a loose wire or blown circuit or something it wouldve stayed off. maybe put it down to a 'gremlin once off' and see if it happens again.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by Dangerous Dave View Post
    Given LCDs work down to -30ºC or so, i doubt that was the problem
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Happened to mine as well on a couple of occasions not only on start up nut when I hit big bumps.
    VE SV6
    May 2011
    Newcastle, NSW
    Yeah I've had this exact same thing happen. When it happened it was on the colder mornings last winter and it only happened when it was colder than normal. But each time after about a minute or 2 it came good. I just put it down to it being too cold for it (for some reason)
    2012 S2 SV6 Sedan
    Apr 2010
    Common fault with the earlier model VE's where the SIC module fails. Had this happen to my SSV where instead of the radio, clock info display is for SV6 and SS I had the volt and oil pressure meter. The fix is the SIC module needs to be replaced eventually.
    If your not living life on the edge, then your taking up space!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by HEXEM View Post
    Any idea on price? Or were you still inside warranty?
    2012 S2 SV6 Sedan
    Apr 2010
    Quote Originally Posted by StoneX View Post
    At the time it was under warranty. A new SIC model for an SSV is $345. Not sure the price for an SV6 or SS.
    Edit: If you're going to buy one, make sure you get the right one for your year model. It takes about an hour to fit and are generally plug n play. No need for tech2 programming.
    VE
    Mar 2011
    n
    Liquid (What)? ...... Hint - not water.
    CV8 Monaro & VE SV6
    Sep 2009
    Happens to mine all the time. I think its got something to do with the light sensor and how it controls the brightness of the dash and auto headlight switch.
  15. #15
    2010 black sv6 ute
    May 2011
    narrandera
    Yea happened to me too, just turned my ute on then off and it seemed fine after that.
  16. #16
    VE CLUBSPORT M6 6.0L
    Dec 2009
    yeah i get that in my clubby to... I push on the plastic around the whole stereo and it comes good
  17. #17
    2012 S2 SV6 Sedan
    Apr 2010
    I don't think the OP was refering to the lighting of the facia controls. They were talking about the SIC or secondary information display which sits above the centre dash air vents.
    When that completely blanks out (no information at all) is it due to a fault occuring in the module. If you keep driving for some time it will eventually come back on or simply cycling the ingnition can correct it.
    Refer pic. The dash info in red.
    Attached Thumbnails Attached Thumbnails has anyone had this happen to there radio clock display-holden-ve-ss-interior-console-controls.jpg
  18. #18
    VE Omega 08 MY09
    Nov 2010
    Gorokan NSW
    Cold weather seems to cause a few problems. Since the cold weather started my auto lights don't work properly until things warm up. When I start up the lights come on because I'm in the garage, they don't switch off when I come out into the sunlight. If I switch them off the dash still looks like the lights are on. ie the electronic speed reading is still dimmed.
    I'm still under warranty so it looks like a trip to the demon dealer, but the problem will have disappeared by the time I get there.
  19. #19
    2012 S2 SV6 Sedan
    Apr 2010
    Yeah Bill44, same thing happens to my car as well. The dimming is standard and once the sensor gets enough light energy it will deactivate. I had my sensor replaced because I thought it was playing up. During winter I notice that the auto lights off - when I back out of the garage takes longer in the early mornings due to the angle of the sun and amount of direct sunlight compared to summer time.
    I went through all this with my dealer and was pretty standard. Having said that I have noticed some security/remote/light sensors are more sensitive than others but by large the majority are the same.
  20. #20
    VE SSV 60th Ann
    Oct 2010
    has happened a few times on mine
    Turns out it is a connection issue on the faceplate. Happened the other morning in fact. I just wiggle the bottom of it and it seems to fix it. At the base of the unit (where the ashtray would go) just put your hand there and turn your fingers up. Grab hold of the ledge and if you pull hard enough you (which isn't hard) you can pull the face plate off. They say to give the terminal connectors a clean with alcohol. Mine seems to be ok and doesnt do it often but
    A video of mine that I showed to the dealer
    YouTube - ‪VE Headunit error‬‏
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
  21. #21
    VE SS 6L M6
    Apr 2011
    Perth, WA
    My display did the same thing (blacking out, returning to normal) happened intermittently for about a week before the fault 'burn in mode' appeared, needed new head unit and lcd for it, luckily under warranty!
  22. #22
    2008 Pontiac G8 GT
    Jun 2009
    Apopka, Florida USA
    This happened to my G8 once back in September last year I think it was.. It was out for one trip then next time I got in the car to go somewhere the screen was back again. Thought it was weird...
    2008 Pontiac G8 GT - White Hot
    Mods:
    Holden Commodore center caps, SCT dyno tune, Volant air intake, SLP Loudmouth axel-back
  23. #23
    MY08 VE SV6
    Jul 2011
    goulburn nsw
    same thing happend to mine after a little physical contact with the fascia hasn't happend since but wont worry bout it anymore replacing whole unit with aftermarket
  24. #24
    VE SS-V
    Oct 2009
    Baldivis, WA
    Yeah same thing happened on mine...only when i started a thread on it no one else had the problem....
    First happened on really hot days then one day never came back on. Next service told them bout the problem and they fixed it with a computer reset (not really sure what that is but it worked)
  1. DAB Digital Clock Radio
    By Darren in forum The Pub
    Last Post: 01-06-2011, 11:31 PM
  2. VE Clock (Audio) display disappears
    By jwk87 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2008, 01:43 AM
  3. WTB: VN console/radio surround with dash clock
    By mwb235 in forum Swap / Wanted to Buy / Trade
    Last Post: 18-12-2005, 08:20 PM
  4. VR commodore Stock Radio Clock
    By jetpilot83 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2005, 06:53 PM
  5. Radio Display Confused!
    By Ari in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2005, 10:30 PM
