Hi guys,
Im in the middle of setting up DRL LED lights that stick under the headlight and im stuck with the modual part. it says to wire to Brown/black of head light which iv done. then to wire the other wire to the "Thin pink/blue wire" Located "at the top R/h side near the fuse box in the engine bay" For the life of me i cant see it anywhere???!is anyone here able to help me out? or able to tell me where there is a Accessories Wire located in the engine bay???? cheers
Itll run from a fuse or a relay to your accessories, check the running to\from the fuse box
why not just wire them to your parkers?
