Results 1 to 8 of 8
Thread: VE Audio Buzz
    VE SV6
    Oct 2010
    newcastle
    Default VE Audio Buzz
    Gday Guys,
    had a quick search and couldn't find much.
    Does anyone have any hints / tricks to remove or improve the buzzing that comes when you have something like a ipod in Aux and charging at the same time?
    Can you change the Neg terminals or something?
    VE Omega
    Apr 2011
    Pakenham Victoria
    i have the same issue, but rather than buzzing, it whistles with the throttle,
    almost sounds better than these things Fake Turbo
    VE SV6
    Oct 2010
    newcastle
    Yeah, that is like mine on occasions. I have tried a in line filter from JayCar but only improved it around 10 - 15%
    VE SV6 Sedan
    Jun 2011
    brisbane
    I kno in my sound system it was a bad earth going to the amp. Once I fixed the bad earth there was no more whine
    07 VE SV6
    Mods: K&N high flow air filter in box, x-force 2.25" cat back system
    Sound System: Alpine type r fronts and rears, 2x Alpine type r 12" sub, Boss audio 1500 watt mono Amp, Kicker 450.1 Amp
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I have the same problem but have you tried to charge your phone and listen through the head phones at home maybe it might be the iPhone/iPod, just a thought?
    MY08.5 SV6
    Aug 2005
    Loganholme, QLD
    It happens in Mine also. Nothing a good overnight charge of the ipod/phone wont sort out if you are planning a decent drive.
    Im a true commy boy!!!
    2007 VE omega
    Feb 2011
    perth WA
    Yeh I started a thread on this a couple of days ago. I've tried 3 different charger setups and no help. Someone suggested getting some resistors put on the alternator by a auto electrician.
    SV6.07's Avatar
    SV6.07 is offline Enjoy it Drive a Holden
    2007 VE SV6 Nitrate & 2011 VE SV6 Poison Ivy
    Oct 2010
    Melbourne,Victoria
    resistors put on the alternator by a auto electrician. should fix the noise. common problem for some cars on audio. get your spark plug leads checked as well. i have had this problem on my current car and 3 past ones over the years. not a hard fix. but go to a good auto elec. dont let him fool u into a new alternator either. u can have resistors added to urs there is only 2 areas on a car u get wine noise when u rev it. alternator and spark plug leads.
    thanks
  1. 2 amps, both buzz
    By vn_v6 in forum Car Audio
    Last Post: 29-01-2010, 11:13 PM
  2. speaker buzz?
    By richardpalinkas in forum Electrical Wiring / Questions
    Last Post: 15-06-2009, 07:12 PM
  3. speaker buzz help
    By richardpalinkas in forum General
    Last Post: 14-06-2009, 06:26 PM
  4. Teen Buzz
    By MOTIV8 in forum The Pub
    Last Post: 27-05-2006, 10:48 AM
  5. buzz buzz
    By VS_chick in forum Jokes/Humour
    Last Post: 24-01-2006, 12:27 PM
