Results 1 to 13 of 13
Thread: engine light on
    2010 Holden VE SIDI SV6
    May 2009
    Default engine light on
    hey everyone,
    i have headers and new exhaust put onto my 2010 ve sv6 and now the engine light has been on, is it a easy fix from holden with the tech 2?
    RUF-60L's Avatar
    RUF-60L is offline Donating Member
    2008 VE SS
    Nov 2010
    holden or any tuning place can turn it off
    Quote Originally Posted by dingdong555 View Post
    Be careful not to hit yourself in the head whilst pulling
    My Ride, RUF60L
    May 2009
    RUF-60L's Avatar
    2008 VE SS
    Nov 2010
    nope, had the same thing happen to mine...i rang the exhaust place and they said even the boss has been driving around with his on for months, doesnt do anything. when i got my car tuned a few months later they turned it off
    My Ride, RUF60L
    f6
    Feb 2011
    There is no reason why the check engine light should be on unless you got your cats changed or they havent plugged everything thing in correctly . I also have a 2010 SV6 With Headers and Exhaust and i had a check engine light but i got it sorted out. Ensure that the Oxygen Sensor extension cables are plugged in correctly . The plugs can be rotated 180 degrees and plugged in the wrong way and it creates a intermittent signal which is what usually causes the check engine light to come on. Most exhaust places dont seem to know anything these days so dont listen to their boss. I know of atleast 3 people who had the Pacemaker system installed that had a check engine light caused by this.
    The car will perform differant when the check engine light is on as the car will run rich. The SIDI Sv6 3.6 engine runs quite rich from factory and this wont be helping. The engine will actually make alittle more power if you lean them up abit especially during the winter months.
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    with the extractors on the sidi sv6 the oxygen sensor has to be extended cause its lower down in the piping ... The computer has a measured resistance in the cabling for the O2 sensor so when it gets extended the resistance changes. the computer thinks this is an air fuel problem and triggers the enigine light ... the only place i know that can fix this (other than holden) is castle hill exhaust in sydney. they claim to be the only ones that can do a tune on these computers ... and with the extractors cat and cat back system the say gains of up to 30 Kw ... thats what i have been told by like 5 different people anyway
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    SIDI sv6
    Jan 2010
    Penrith
    vx custom 600RR
    Oct 2010
    your car no longer needs a tech 2 as it is now OBD2
    you can take it anywhere or buy the interface and do it yourself
    SIDI sv6
    Jan 2010
    Penrith
    sorry man but i have no idea what ur talking about can you please explain that in a bit more detail
    f6
    Feb 2011
    NO tuning is required with the headers . I have the pacemakers with the oxygen sensor extension cables and i have no check engine light. I have fixed a mates car he had the sensors plugged in wrong i did that and reset the ecu via disconecting the battery and no problems.
    Monaro CV8R, Landcruiser 100 Series 4.7L
    Jun 2011
    Should be unrelated but my CV8 Monaro did the same thing although only temporarily. I had Pacemaker tri Ys fitted and about a month later the engine light came on for about a minute. Never saw it again. Puzzling.
    VE Omega
    Nov 2009
    Here
    Out of the blue my check engine light come on and stays on and every time I take my foot off the accelerator to slow down or brake the ESP turns itself off and when i reach a certain speed it turns itself back on again beeping the whole time it is doing it. Or just stays off for X amount of kms and turns itself back on again. I am at my wits end with this, the beeping is driving me insane and I have to have the music loud just to drown the noise out. It has been doing it for a while now and Holden told me that as long as the engine light is not blinking there is no real issue. Well the "no issue" my car slid out badly. Turning ESP off on the console makes no difference as it just beeps away and flashes anyway. As soon as I turn the car on check engine comes up on display and the light stays on. How do I fix this??
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Vt 5.0 idle problems and missing also engine light and oil light come on
    By vtss5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2011, 07:32 PM
  3. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
