Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By revinR1
Thread: How to change the VE headlight globe
    Commodore Omega
    Aug 2010
    Fairfield, Melbourne
    Default How to change the VE headlight globe
    I have noticed that my right hand side headlight glob is not working. Is is easy to change my self or do i need to go to the service center/auto mechanic ? please advice..
    Commodore...of course
    Apr 2010
    VE Calais, VR Wagon
    Aug 2009
    Quote Originally Posted by VEman View Post
    Can be a bit annoying as you have to remove the front bumper, this guide should help
    http://www.iagresearch.com.au/index....d=29&Itemid=40
    That's interesting, on mine you just take off the dust cover on the back of the headlight. It's a bit tight for space back there. But it should tell you how to change the globe in your owners manual.
    Quote Originally Posted by QuickVRII95 View Post
    I Outsmart Defence Force Psychologists... My IQ "IS" Also Over 165.....
    My VE Calais http://forums.justcommodores.com.au/...my-calais.html
    My VR Wagon http://forums.justcommodores.com.au/...-vr-wagon.html
    ClairBear's Avatar
    ClairBear is offline Make the stupid stop!
    VE Omega / Hyundai Getz
    Nov 2003
    SA - The Murder State
    That link is a guide for crash repairers to dismantle parts off the car, not a guide to change the headlights. AFAIK you do not remove the bumper bar to change the headlight.
    Quote Originally Posted by commodore1310 View Post
    Ok, once again ive run aground with a bunch of elitist PRATS who think they know it all, stuff your cars and stuff your forum!
    Quote Originally Posted by one_and_only2004 View Post
    No, driving a v6 engages GOD MODE. Please don't continue the argument...
    VE Omega 08 MY09
    Nov 2010
    Gorokan NSW
    VE SV6
    Jan 2011
    Maitland
    For the drivers side just pull upwards on your overflow tube (it pulls out) move it aside, look over the top and remove the dust cap closest to the inner guardby twisting it (thats the low beam ) pull the black light fitting off the globe, push and flick the chrome wire holding in the globe pull out old globe insert new globe and reverse process. For the passengers side you`ll need a phillips head stubby scfrew driver to undo the washer filler neck and push it aside then its the same process. should take all of say 15 minutes. The little T10 parkers globes if you want to replace them also they just pull out and push back in
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Definitely do NOT Pull the bumber off LOL.
    Its the same process as any standard headlight glob. As i learnt last week when i did this for the first time on a VE, MAKE EXTRA SURE that you put the globe in with the tab pointing UPWARDS !! This confused the fudge out of me because when you look inside the housing there's something that looks like a nicely made metal track for the tab on the globe, but NO, its just there to confuse you and it is actually the support bracket for the reflector cap inside the headlight .....
    If you put the globe in the correct way it's easy as.
    VE SV6
    Jan 2011
    Maitland
    You might find it easier to remove the engine instead to access from behind
  1. Headlight globe replacements
    By 2DIE in forum General
    Last Post: 26-11-2010, 08:22 PM
  2. headlight globe
    By CommVTS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2009, 01:47 AM
  3. VY to VZ headlight change..
    By jamesl_VTSS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-01-2009, 01:49 AM
  4. Change aircon globe in vs series II executive
    By macca_223 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2008, 11:57 AM
  5. Change brakelight globe for vs
    By guns2006 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2007, 07:49 PM
