Results 1 to 13 of 13
Thread: SSV rear light - fogging up.
    Luke V8's Avatar
    Luke V8 is offline AKA Luke!
    VE Commodore SSV
    Feb 2011
    Default SSV rear light - fogging up.
    Hi All,
    I have just noticed tonight that my drivers side rear light has started fogging up. Is that it now, new lights?!
    What causes it?
    Pic Added:
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Might be a common problem-
    Ve clubsport rear lights
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Quote Originally Posted by pjdm1980 View Post
    That's more about led lights blowing in a clubby?
    Mine is fogging up on a rear SSV light - different setup completely to the clubsport
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    Fogging up is usually caused by moisture inside the housing. Is the tail light cracked or anything?
    Series II SS
    Jul 2010
    There was a thread or 2 about this quite a while ago, It was considered a problem a several of the early VE's, I had it on my SV6 ute at random times.
    IF YOU BUILD IT THEY WILL COME.... STILL WAITING LOL
    Mike08's Avatar
    Mike08 is offline No Back seat drivers
    VE SS Ute
    Feb 2009
    Queensland
    Warranty job mate, keep going back till they fix it.
    If you still have warranty that is.
    I don't know how old your car is.
    Cheers.
    Mike
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Checked and no visible cracks etc ...
    2007, about 33,000ks . I got it privately, the car had warranty to 2013 but when I called holden they told me.
    1. Car hadn't been serviced by them (It has been serviced on time etc but by a local mechanic I know)
    2. Warranty is not transferable(!!)
    I know the guy I purchased it from and he never bothered taking it to the main stealers *ahem dealers* as they threw extended warranty in for free. But he figured they would make money back with Holden servicing!
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    probably wouldn't have been covered by extended warranty - only the original manufacturer's warranty - which is transferrable - but only lasts 3 years.
    I'd say there's an issue with the seal around the lens cover.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Hey mate, my back left light on my ute was fogging up, i couldnt see any cracks or anything, got it replaced under warrenty, hasnt done it since
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    This seems to be a problem with VE's which have undamaged tail-lamps, yet accumulate moisture inside. My son's Omega has the same problem and it seems to be that the seal is defective.
    Wouldn't the simplest solution for someone whose warranty has expired, to be just remove the tail-lamp and blow it out with compressed air, then run a small bead of silicon sealant around the join between the lens and housing? Seems pretty obvious to me.
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Commodore
    Jun 2004
    NSW
    I have the same problem with SSV light on my sv6
    It's only right hand side and it fogs up (not much though)
    Same area as you lights in the picture
    I'll remove it and check the seal on it.. Can't think of anything else as there are no visible cracks or anything like that ...
    SV6.07's Avatar
    SV6.07 is offline Enjoy it Drive a Holden
    2007 VE SV6 Nitrate & 2011 VE SV6 Poison Ivy
    Oct 2010
    Melbourne,Victoria
    mine does the same on SV6
  1. Bad condensation and fogging on inside of windscreen
    By ads18x in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-06-2010, 12:28 PM
  2. Projector headlight fogging up...?
    By BANKS in forum General
    Last Post: 30-05-2009, 01:11 PM
  3. VE GTS Back tail lights fogging
    By ondie in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-11-2008, 11:37 AM
  4. Windscreen fogging up
    By GMBanisher in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2008, 08:59 AM
  5. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
