Results 1 to 3 of 3
Thread: Sat nav turn by turn
    2010 VE SSV ute XYZ XYZ
    Jun 2011
    Default Sat nav turn by turn
    My SSV has factory sat nav - there is an option on set up for turn by turn nav - also option to do same with steering wheel buttons - does that mean that a should have the turn arrows come up on my dash screen is between speedo and tacho? It doesn't am I'm wondering whether that is cos it's a fault or driver fault cos I haven't set it up properly before I take it back to dealer
    Can anybody help? Cheers
    VE Calais V, V8
    Jul 2009
    My Jan 2008 Calais V has factory navigation. The navigation info appears between tacho & speedo. For me, just need to be in the correct mode. So, press the 'trip' (from memory, I haven't been in the car for a few days) button on the LHS of the steering wheel. The button that runs through the various display options - so odometer, trip, speedo (if optionally turned on), etc, etc. One of the modes shows the navigation arrows. HTH. regards, Pete
    Jun 2011
    Thanks Pete
    Yes I selected that option (and read the manual lol) and it doesn't show any arrows between the tacho and speedo
    Just one quick ques / do you need to select any option on the nav itself?
    If not, I think I need to take or back to the dealer to check it out
    Thanks for helping
  1. Key won't turn?
    By tristan2355 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2011, 08:08 PM
  2. a/c - fan will not turn off
    By holdenvtece in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2010, 02:36 PM
  3. Car won't turn over
    By scouserrules in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2009, 10:20 PM
  4. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
  5. Problem with amp turn on/turn off
    By don80 in forum Car Audio
    Last Post: 05-06-2005, 08:06 PM
