Results 1 to 17 of 17
Thread: Starting Problem/Engine Imobilised
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Question Starting Problem/Engine Imobilised
    Hey all
    Having a bit of a problem with my 2008 VE SSV ute atm just wondering if anyone here has heard/had the same problem
    Basically it does it warm or cold, you put the key in and start makes a few clicks tries to start then stops, then engine imoblised comes up on the screen usually u pull they key out and try again it works, sometimes also you start it, it makes a click then starts
    Now ive got a brand new bigger heavy duty batt put in and a brand new key, which i though they would have fixed it
    I just got off the phone to Holden they think it may have something to do with the BCM its booked in for thursday, just wondering what your thoughs on what it might be
    Ive also had the starter checked they said its fine, and if it was that wouldnt it play up everytime i start it? ive also had my alternator checked working perfectly fine
    Apprecaite any help lads, Cheers
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    HUX 90's Avatar
    HUX 90 is offline POSION VE SS UTE
    09 VE SS UTE
    Mar 2011
    I haven't had this problem, but the only help i can think of is mabey ring a few auto electrics companies and see if they have had anyone come in with a VE with the same problem, could also be the immobiliser but that's just a guess.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by HUX 90 View Post
    Yeah, well hopefully holden can figure it out thursday if not i think i will make a few more calls, i was thinking tho havn a mafless tune wouldnt effect the immobilser or bcm ect would it?
    HUX 90's Avatar
    09 VE SS UTE
    Mar 2011
    I doubt it, well from what I've read it doesn't seem likely that a mafless tune would but again thats just a guess from what I've read.
    HUX 90's Avatar
    09 VE SS UTE
    Mar 2011
    You could ring your tuner and ask he would probably be the best person to ask.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Yeah, i got mine done through oztrack, he just told me it hasnt got anything to do with it, hopefully its just a computer thing and holden can fix it, sick of not knowing what its going to do every start
    HUX 90's Avatar
    09 VE SS UTE
    Mar 2011
    Yeah that's what I thought, mafless tune would probably only effect the ECU where as the BCM would have more to do with the lights, locks, power windows, electrics etc.
    SV6.07's Avatar
    SV6.07 is offline Enjoy it Drive a Holden
    2007 VE SV6 Nitrate & 2011 VE SV6 Poison Ivy
    Oct 2010
    Melbourne,Victoria
    i had the same problem it turned out to be my new key. wasnt programmed right. . got it redone and never had the problem again.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by SV6.07 View Post
    Oh ok it was doing it with my old key aswell, so i doubt the new and old key is causing it
    2012 S2 SV6 Sedan
    Apr 2010
    Mate I will post a video of what I think your talking about... lemme know if its it..
    9:02PM EDIT: Ok I have found the file..
    http://s280.photobucket.com/albums/k...StartIssue.mp4
    Phil
    If your not living life on the edge, then your taking up space!
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by HEXEM View Post
    HardStartIssue.mp4 video by VE-SSV - Photobucket
    Phil
    Yeah mate, mine usually doesnt take that many times, did u have to pull they key out and retry each time?, and did the engine imobillised come up on the screen for you? i did notice you have the same clicking noise i have
    SV6.07's Avatar
    Oct 2010
    Melbourne,Victoria
    i still feel its could be the key need reprogramming. both ones. immobilisers is linked to the keys. going by what Holden told me.
    2012 S2 SV6 Sedan
    Apr 2010
    Mate I had the larger battery installed and the charge rate increase (Via TECH2 - Set to POLICE MODE for charging) which got rid of it. I didn't notice immobilised come up as I was out of the car when starting it. Those clicking sounds you hear are me turning the key... lol...
    What I found was if I kept the charge up regularly to the battery it wouldn't do it. That video is where I was using the OEM (small 450cca) battery with a new reprogrammed key, it would start by only doing it every now and then to what you see in the video...
    When I changed over it would only do it a couple of times. Then when I had the charge rate increased it hasn't done it since. But I also have completely brand new key (no bits from the old one). I think it could be a bit both issues (lower than normal voltage and key remote).
    If you put a bigger capacity battery in you should have the charge rate adjusted to compensate for it. Mines a 600cca battery (same as the one in the WH)
    Phil
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Phil
    Oh ok the clicking noise i meant was the 2nd time u tried to start it it just clicked, i think mines a 500cca if i remember corretly, i also got a totally brand new key reporgammed, even if i go for a hour or so drive come home the next day it will still do it, so im not sure if mines a charging problem
    I will update this thread once i find out thursday from holden what the problem is, ill also tell them hex about raising the charge, cheers
  15. #15
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Well heres the update, apprently one of my battery terminal were lose causing the engine imoblised part due to it arking, now as for the click thing my starter is dieing so going to get a few quotes and get a brand newy lol
  16. #16
    HUX 90's Avatar
    09 VE SS UTE
    Mar 2011
  17. #17
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    The warrenty for it ran out in feb
  1. WH/VT starting problem
    By ivanov in forum Electrical Wiring / Questions
    Last Post: 04-09-2010, 06:51 PM
  2. VT 5.0 starting problem
    By jb2020 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2008, 11:22 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. Starting problem
    By gooley in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2006, 09:47 PM
  5. not starting problem
    By mawoet in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2005, 11:56 AM
