Results 1 to 25 of 25
Like Tree1Likes
  • 1 Post By Thumpin
Thread: Ticking noise
    VT S-Pack S2
    Sep 2010
    Default Ticking noise
    Morning everyone,
    Just wondering, my old man has a VE E2 HSV, and im not sure if its a normal thing but the engine 'ticks' alot, my mate has a VE E2 Maloo, and it barley does it at all...
    So yeh just wondering if its a normal thing or not, its done 17xxx kms if that helps with someones response.
    cheers
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    Have a read of the thread on lifter rattle. There are some good videos posted in there. Have a listen and see if that is the sound you're talking about.
    2012 S2 SV6 Sedan
    Apr 2010
    It could be lifter tick or injector pulse.. The fuel injectors are pretty noisy on these cars.
    If your not living life on the edge, then your taking up space!
    2012 S2 SV6 Sedan
    Apr 2010
    On the far side, you might have picked up on the engine life count down (or holdens). You have to guess when it goes off..!!!
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Has it got extractors or the engine cover off, that seem to make the noise louder on mine.
    VT S-Pack S2
    Sep 2010
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Also mine had a cat gasket leak an sounded like a lifter, put your head under the car and get someone to give it a rev.
    VE MY10 SV6 A6
    Feb 2010
    Regional South Australia
    I also have a ticking noise on my MY10 sv6. Just about every VE I've test driven/walked past, has a ticking noise. Thing is, mine is much more noticeable, unless I'm paranoid. It's still under warranty, so I'll have to head to Holden I guess.
    VE SS 2010
    Jul 2011
    Lifter tick.
    From hexems saga you would know if you have a problem.
    Mine ticks too but its normal.
    No Replacement for Displacement
    2012 S2 SV6 Sedan
    Apr 2010
    Not even going to comment!.....
    VE II SSV Sportwagon
    May 2005
    top of Sydney basin
    Quote Originally Posted by sus_038 View Post
    Morning everyone,
    cheers
    Yer they sound a bit like a meccano engine. They tick, rattle, fart & smell which is quiet normal for this dinosaur design. Its hard to tell if your noise "tick" is outside the normal realm. If its a constant tick noise over & above the normal racket then its worth getting it checked-out.
    VE II SS-V Sportwagon
    VE SS 2010
    Jul 2011
    Quote Originally Posted by Thumpin View Post
    Dinosaur design alright, but cheap to fix and upgrade me thinks.
    2012 S2 SV6 Sedan
    Apr 2010
    Quote Originally Posted by Advanced_Amatuer View Post
    You wouldn't think so with all the sh!t I've had to put up with.
    A basic rebuild on these engines will set you back around $4,000 and with no gaurentee that it will fix the issue either!. You can buy new 'COMPLETE' LS3 (current HSV engines) for under $7,000 fitted from some of the performance shops.
    VE 6.0l SS Ute
    Oct 2011
    Tamworth
    mine did that and next minute one of the lifters failed so i would go and have it checked out
  15. #15
    VE Clubsport
    Mar 2010
    Middle of Nowhere - WA
    Mine has ticked forever & a day. I'm pretty sure that there's nothing wrong.. Had it serviced couple months ago & they never said anything needed any work.
    I'm a girl... I'm blonde... But I drive a really nice car
  16. #16
    VX acclaim S2
    Oct 2009
    Quote Originally Posted by LittleMissVT View Post
    + 1 there
  17. #17
    VE Clubsport
    Mar 2010
    Quote Originally Posted by kizza50 View Post
    + 1 there
    Is that bad?
  18. #18
    VZ SS 5.7l
    Sep 2011
    My dads SV6 has been ticking since the day it was new in 09
    Not sure about the pre SIDI or AFM models
    but im guessing its as someone here mentioned, just the fuel pump?
  19. #19
    WL CAPRICE
    Mar 2011
    I know that the purge solenoid ticks in my alloytec it might just be that.
    What's the job of the purge hose and the purge solenoid anyway? Lol
  20. #20
    VE MY10 SV6 A6
    Feb 2010
    Had mine checked other day, and was told it's normal too. Probably the only gripe I have with these cars so far.
  21. #21
    SilverVH is offline Banned
    Nov 2005
    Depending on how severe the tick is (could just be injector pulse that you are noticing) I would definately get it checked out.
    An LS2 or LS3 shouldn't suffer from lifter rattle like the early L76/L98 6 litre.
    Same goes for the OP.
    The HSV variant is different to the Holden variant and isn't plagued with issues.
  22. #22
    VE Clubsport
    Mar 2010
    Quote Originally Posted by SilverVH View Post
    I've had next to no issues with my car (apart from the freaking grinding sound it likes making when reversing in the morning) - the tick isn't that bad and only something that I notice (have turned the music down & asked passenger to listen.. they hear nothing. I'm just paranoid I think sometimes).
  23. #23
    Nov 2005
    Maybe you forgot to take your Cartier watch out of the glovebox?
  24. #24
    VE Clubsport
    Mar 2010
    Lol. No, I'm more so thinking it's the 400 diamonds that hang from the rearview mirror.
  25. #25
    2012 S2 SV6 Sedan
    Apr 2010
    since the new engine when in my injectors a quite loud now. Took it back to the dealer and they said they noticed the injectors noiser than normal. Didn't offer a fix though. They are the original injectors but were never that noisy.
    Maybe they work it's just that the engine is quieter?... hehe
    Anyone go a fix for noisy injectors? is it a lub issue or something else...
    Phil
  1. VK Ticking Noise.
    By Pie-VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-02-2011, 12:38 AM
  2. vt 5.0 V8 Ticking noise
    By jesse'sVT5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2010, 05:17 PM
  3. Ticking noise on LS1
    By helicraze in forum LSx Development and Modification
    Last Post: 09-09-2010, 10:05 PM
  4. Ticking noise
    By Cameron P in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2010, 05:53 PM
  5. Ticking noise!
    By ucd939 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2008, 05:30 PM
