hey guys just wondering if these are actuallyany good.
i like the concept of it but am not 100 percent sure how it all works.
you would need to jackyour car up eachtime you wanted to change it right?
And whats the ride like, is it good suspension or really bumpy and what not.
any help ould be great thanks guys
Depends on how much you're prepared to spend, really. If your budget is around the 2K mark, you can do better for the money - but if you're prepared to spend 6K+ - go for DMS!
Personally, i thought about coilover but instead went for springs and shocks and i'm rapt with the result. Are you going to adjust them all the time?
And as snips said, if you go coilover go something good.
Ah ok then I have a mate at bursons and can get them cheap and depending on how easy they are tO change would depend on how often i do it.
I just want the option to go really low and then if I was going away or needed to raise it for any reason I could easy
I have Pedders fully adjustable suspension on my car i can adjust the height and the stiffness no complaints here feels nice depends what your budget is as said above. but every time you adjust the height which isn't that easy to do you have to get a wheel alignment im told
Check Out My Ride
Dash Gauge Install
I thought adjustable meant... primarily meant shock dampening/stiffening???
if you want to go really low go airbags, coilovers dont go that low.
