Same engine, heavier car....why does the VE feel so much more responsive?
I believe that the VZ Alloytech put out 190KW in the SV6, whereas the VE Alloytech was 195KW pre the SIDI.
However, the biggest difference appears to be torque delivery. Both engines had the same 340 NM, but the VE figure was at 2,600 rpm versus 3,200 in the VZ, i.e. higher torque at lower rpm for the VE.
No actually it's series 1 Vz is 175kw and series 2 Vz is 190kw.. I know because I have one..
those specs are wrong!
VEs are either
2006 - 2009 Late:
195kw
2009 to present:
210kw SIDI
Just buy a V8 and it will be faster than both. <--- Someone had to do it![]()
There is no such thing as stupid questions, Only stupid people.
VZ V6 '04/'05 models excutive,acclaim and berlina 175kw. '06 172kw=loss of 3kw because of emissions regs i think. I carn't remember about SV6 and Calais (190kw) engine if it changed power figures. We have a 04 VZ acclaim and a 08 VE lumina in the family, and the VE fells alot more responsive than the VZ alot more than the claimed 10kw or so difference (VE 185kw i think?).
Cheers.
[CENTER][URL="http://forums.justcommodores.com.au/showthread.php?p=490264#post490264"]
Different gearing mate.
The torque/power curves are marginally improved in the 195kw, transmisson and the gearbox are also better and the car gets better traction off the line with IRS and a decent suspension. It also has slightly better diff gears 2.83 vs 2.93? (not sure if thats exact), theres some other differences to do with cam phasing etc
Kuzman's Supercharged SV6 - MACE TUNED
I thought the omega were only 180kw... So whats the difference with the high output badge on my sv6? I know mine is 195kw apart form the obvious![]()
Are they both high output/low output engines and do they have the same gearbox? A 4 speed VZ with single Variable cam phasing would get smashed by a 5 speed VE with intake and exhaust variable cams regardless of the extra weight
