Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By boneart
Thread: How To Remove The Stereo of VE Commodore SV6 07
    VE
    Jan 2010
    Bahrain
    Exclamation How To Remove The Stereo of VE Commodore SV6 07
    Guys,
    I want to know how to remove the stereo of VE Commodore SV6 2007 model, below the picture of the stereo.
    Appreciate if you provide me the explanation with pictures.
    Thanks in advance.
    VE Omega
    Nov 2009
    Here
    VE
    Jan 2010
    Bahrain
    VE Omega
    Nov 2009
    Here
    Quote Originally Posted by tariq View Post
    Cuz I need to add a cables for the subwoofer speaker.
    There are NO RCA inputs on the back of the stereo. You will need either a line converter or if you have alot of cash a crossover converter to be able to attach an amp to the lines.
    VE
    Jan 2010
    Bahrain
    VE Omega
    Nov 2009
    Here
    VE Omega
    Nov 2009
    Here
    Will go ahead with converter, but how i can remove it bro ?
    Apparently it just slides out of the holder. Also the faceplate comes off too.
    Unless you are really good with stereo equipment I recommend highly paying a professional to install the converters. The line converters are $25 - $200 and take them about 2 hours. Your security runs through your stereo too so don't play around with it or it might end up costing you alot more after paying to have stuff reset.
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    Quote Originally Posted by Z3RO View Post
    This.
    Removing/disconnecting stereo might cause you dramas mate, make sure you know what youre doing in there.
    VE SS-V
    Sep 2009
    Auckland
    Hi Tariq
    Firstly I would not do it as there are too many things running through it HVAC and security so unless you know what you are doing you could end up paying heaps to Holden to reprogram it all for you.
    Secondly if you are only wanting to get at the audio and speaker inputs/outputs etc then those are on the right hand side of the unit not at the back so you don't need to pull the unit out.
    To get at the inputs just pop the side panel of the driver foot well off and you will see the plugs on the side of the unit. This plastic panel just pops out then slides down and out from under the dash trim. If you have any problems doing that pull off the V trim piece along the dash just above the steering column to get at the screws that hold the underside of the dash in place. Its pretty easy.
    Once you have that panel off you can then also get behind and under the unit if needed to run cables or look for connectors.
    If you want to remove the radio front panel (which as I said you don't need to do to access the audio plugs) then simply pull it out and up from the bottom above the ashtray or tray.
    If you want to remove the unit itself then you will now see approx 4 screws in the metal panel that need to be removed BUT.....
    Before you can pull the unit out you need to remove all the plugs not only from the right hand side of the unit as above but I also remember one or two on the left hand side so you will need to take the passenger side panel out as well to get at those. This panel can be removed with a little careful pulling and bending but sometimes you end up having to take out the glove compartment to get clear access to it.
    Once again, I would not recommend doing this or unplugging stuff unless you know exactly what you are playing with.
    I had all these panels off to install a backing camera, switching unit and VIM (which connects to a plug behind the glove box), its not hard but it is time consuming so its not something you want to do if you don't have too.
    UFO's Avatar
    UFO
    Oct 2009
    Now that's a nice detailed "how to" post! Very well written and easy to understand .
  1. How To Remove VY Seats/Stereo surround etc..
    By sweefu in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-07-2010, 11:01 AM
  2. Easy way to remove stereo?
    By VS Omega in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-05-2010, 07:33 PM
  3. Replies: 1
    Last Post: 18-05-2010, 03:08 PM
  4. How do you remove Holden Assist from stereo?
    By anonymousmoose in forum General
    Last Post: 25-03-2010, 03:25 PM
  5. Remove VX stereo
    By matt_gotigers in forum Car Audio
    Last Post: 23-01-2008, 12:18 PM
