Results 1 to 12 of 12
Thread: warranty issues...
    VE SS karma blue
    Jul 2009
    Default warranty issues...
    my 2008 VE SS is just out of warranty by a few weeks, it's rear brake sensor has been playing up for a while though and after its latest service it looks like the sump gasket is stuffed too (they suspected a problem with it at the previous service, just confirmed at the last one, handbook services with ultratune). Reckon Holden will fix these issues as they were present while the warranty was still there or will they tell me tough luck? Will be contacting them next week anyway...
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Never know your luck if the problem was diagnosed before warranty they might do it.
    VE SS Sportwagon
    Feb 2010
    Brisbane - Southside
    if it is on record before the wnty ran out, and it is a wnty item, then they should fix it no problem.
    I doubt the gasket will be covered unles you've done bugger all kms.
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    Yep.... as already said, because it was a documented issue prior to warranty expiry you shouldnt have an issue.
    Ve-SV6 9.5
    Jun 2011
    Hervey Bay
    Default Warranty List I Made, Was it too much???
    When I took the car and this list into them this morning, (They didn't seem too impressed)
    Do you think I went too far or is this reasonable?
    Your opinions appreciated...
    Tuesday-5th-July-2011 Please Check the Following Under The Holden Warranty
    1. Wind blowing through front door seals (The top of the drivers door can be seen moving in and out away from the body on bumpy roads, this could also apply to passengers door) Lack of passengers…
    2. Strange INTERMITTENT knocking noise underneath 5 or 6 knocks that can be supplely felt through drive train… (Mostly after start up when turning right) ONCE there was a loud click followed by a ratcheting noise similar to CV noise or collapsed bearing???
    3. CD player (Head Unit)
    4. Clunk in rear end (Possibly Bushes?)
    5. Possibly Universal JNT’s or DIFF a little worn as it’s a bit slappy/clunky through gear changes??? ALSO has a droning wine when cruising (Gearbox or Diff???)
    6. Rear Brake (LED Light in rear window) has some blown LED’s
    7. Brake pedal seems a little spongy? Please check any warranty stuff here…
    8. Please Check all Engine Gearbox Mounts
    9. Engine belt pulley’s seem a little noisy?
    10. Please inspect all bushes front & rear
    VE II SSV Sportwagon
    May 2005
    top of Sydney basin
    Quote Originally Posted by panthergreen View Post
    I heard (but haven't seen it) about a tech bulletin issued regarding sump leaks on the V8's. Apparently its directed at the AFM engines only but non-AFM's are seeing it too. I would talk to your dealer about warranty as the problem was around during the period your car was warranty covered.
    VE II SS-V Sportwagon
    May 2005
    top of Sydney basin
    Quote Originally Posted by Velocity View Post
    Glad I'm not the mechanic trying to work this wish list.
    Its best if you take the tech for a ride and show him what you are hearing/noticing. There not going to spend hours trying to make something show its ugly head. Some of it might be known issues which they can deal with but #2 & 5 would be asking a bit much, IMO.
    Ve-SV6 9.5
    Jun 2011
    Hervey Bay
    Thumpin: I'm pick'n up what you're putt'n down, "Poor Techies & Mechanics" However if I don't say anything then how will they know to look? + warranty will be done and dusted soon in less than 12 months so needed this stuff documented now so they have something to refer to incase of future problems...
    Can you offer suggestions as to how I should have handled it? (That's a genuine question and NOT meant to be a wise crack)
    It's not my intention to piss anyone off, more just want to dot the i's & + the t's
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Are you saying that Ultra tune did all the services or just the last one? If they have done all of them you should have reported it before the warranty ran out (If thats the case I'd say no) but if it is as most people here are assuming (Holden serviced) then you might have a chance depending on how you handle it.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Generally the faults need to be reported TO Holden while under warranty to be covered beyond the warranty expiry period. Being diagnosed by Ultratune wont count for much I imagine.
    1. Common issue is people hanging off the door to get in and out and it gets bent out of shape.
    2. Front suspension knock can be a lack of spring insulators, worn swaybar D bushes or collapsed strut top bushes.
    3. Whats the issue?
    4. Rear end clunks fairly uncommon in VEs
    5. Backlash is common
    6. The LED strip is rep[laced as it cant be repaired
    7. May need a good bleed
    8. Engine mounts do fail not uncommon
    9. Any signs of coolant leak? P/S pulley may be out of alignment or it may just need new belts.
    10. Refer to 2
    Dont like your chances of getting any of it fixed for free personally.
    Silver Certified.
    VE SS Sportwagon
    Feb 2010
    Two different guys telling their stories here. Sounds like Velocity has another 12 months warranty left to sort his issues out.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Ok - lets start with item 3: What about the head unit?
    Item 6: should be a warranty repair
    Items 7,8&10: Your mechanic should check all these during regular servicing
    All the rest sound very much like a car that has had the wheels thrashed off it from the start and/or been in a major shunt. You *may* get some of them under warranty but it has a lot to do with how sympathetic your dealer/GM area rep is.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  1. What should i do? Warranty issues!
    By kause in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-04-2011, 10:53 PM
  2. Warranty issues
    By IceyAUS in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-03-2011, 01:47 PM
  3. Warranty issues.
    By DANNY8 in forum The Pub
    Last Post: 10-10-2008, 01:57 PM
  4. Approaching End Warranty - Possible Issues?
    By kipela in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-02-2007, 05:30 PM
  5. do it yourself service warranty issues
    By Tony2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-09-2006, 06:54 PM
