Results 1 to 11 of 11
Thread: Will extractors and cats cause L98 to throw a code
    brad VE SSV's Avatar
    brad VE SSV is offline Soon to be Harrop charged
    2011 VE SSV redline wagon
    Mar 2011
    NSW
    Default Will extractors and cats cause L98 to throw a code
    Hey all, I have a ve ssv which I believe Is a L98 6.0L motor. I got a lukey 2.5" catback exhaust in stainless.. And am now looking at using a set of PH5377 tri-Y pace'y extractors (ceramic coated) and high flow cats ( in 2.5" ).
    Will this cause the computer to continually throw codes??
    I have a Vz sv6 with a full exhaust (been dyno'd) and it throws check powertrain code all the time on all 4 sensors...
    Just won't do headers if it'll end up like the Vz...
    Any of U guys have any problems...
    ve ss
    Feb 2010
    Gold Coast
    Mate I'm pretty sure once a full exhaust goes on u have to get it tuned and they fix all that so It doesn't happen.
    If u had ur vz done did u get it tuned or just dyno run?
    Mar 2011
    NSW
    Nah got headers Cats and full tune at castle hill exhaust.. I already had 2.5" catback..
    I paid $2200 and wasn't real happy with it...
    2012 S2 SV6 Sedan
    Apr 2010
    the code relates to the O2 sensors (both position and exhaust temp)as you have mentioned. If you installed 100 or 200 cpi cats the exhaust gas temps change which can cause the system to throw a code. Also if the paceys position the cats further back from the factory position causing the O2 sensors to be in a different position this too can cause the system to throw a code.
    All this can be rectified by a tuner. They will simply turn off the range parameters so it wont check for it.
    If your not living life on the edge, then your taking up space!
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    ive got ceramic coated packy's and 100cpi cats with a oztrack tune and there is no codes comming up for mine, so id say u will be fine with a good tune
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Mar 2011
    NSW
    Yeh will be looking at KPM for a tune in Adelade.
    These headers for ve are meant to bolt up to original cats position.. Think it's the 4 into 1's that need the sensor extension..
    So by the sounds if it going back to a tuner will fix it on Vz?
    Mar 2011
    NSW
    Also add (not sure if it matters) but it throws the code when coasting or when foots off accelerator.. And some times clears itself, others gets done at Holden
    Cheers brad
    2012 S2 SV6 Sedan
    Apr 2010
    yep take the VZ to your tuner and get him to turn off the sensor code. If you get the try Y's the cat will be in the same position as factory. What might throw a code though is hi-flow cats. This is becuase the gases do not heat up as quickly as say 400cpi ones. So the sensor may not be happy. Some have been able to install hi-flow cats and not have an issue (even without a tune). I think it depends somewhat on the brand.
    If you get an Oztrack tune (mail order or remote tune) Steve will have this issue fixed in the tune so not further problems.
    Phil
    VE SSV 60-th Anniversary
    Jan 2011
    I did mine at KMP Adelaide... 3" full system, OTR and TUNE, no code issue...
    2012 S2 SV6 Sedan
    Apr 2010
    That's because in when they do the tune they set it so it wont throw a code..
    Mar 2011
    NSW
    Sounds great... Thought it was strange Holden wanted to change all 4 sensors..
    Just means I will do extractors, cats, VCM otrcai and tune all together so I have no problems...
  1. [VIC] LS1 hi flow cats and HM extractors
    By mat vsII in forum Parts And Other Items For Sale
    Last Post: 02-05-2011, 02:37 PM
  2. Which cats/extractors for a VZ SV6
    By 1FATVZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-09-2010, 07:51 PM
  3. So... I have extractors and a hsv exhaust. Now to the cats!
    By TobyDSim in forum V6 Development And Modification
    Last Post: 15-07-2010, 06:47 PM
  4. SS Extractors and Cats
    By Skooby in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-01-2009, 03:11 PM
  5. [NSW] WTB: HSV VY II SS Extractors and cats.
    By Skooby in forum Swap / Wanted to Buy / Trade
    Last Post: 17-12-2008, 01:15 PM
