Results 1 to 22 of 22
Like Tree2Likes
  • 1 Post By Bradbd
  • 1 Post By bonners
Thread: Brake Calipers
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    Default Brake Calipers
    Ok i know that some of you are going to be ########s but here it goes anyway ...
    I am wanting to paint my brake calipers ... does anyone know of somewhere that you can get the paint for doing this, and is there a fairly wide selection of colours or just like 4 or 5
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    You'd probably just be able to clean/prep them, undercoat and paint with high temp paint.
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    fairly certain high-temp paint is self priming (going from my increasingly unreliable memory) - you can also pick up 'calliper paint' from Repco (used to be able to at least) - same stuff though, different can and probably 5 bucks more expensive!
    VE S2 SV6/A6
    Apr 2011
    I have found 3M make the best stuff, only 5 minutes between coats, rather than an hour plus from some that I have used. Nice glossy finish too, and no, they don't require primer, just make sure you prep the calipers right with a wire brush (or better still a wire brush attachment on your electric drill) and then some wax and grease remover, then just spray away
    Current Ride: 2011 VE Sedan - In Voodoo of course.
    Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
    Also Own: 1964 EH Wagon, modified interior, minor modifications outside
    2007 VE SV6
    Jun 2011
    SIDI sv6
    Jan 2010
    Penrith
    thanks for the link ... and good to know its easy to get the paint ... but would i just get it from any car shop or something ...
    Also i have attached a photo of my car ... opinions on what colour?
    RUF-60L's Avatar
    RUF-60L is offline Donating Member
    2008 VE SS
    Nov 2010
    black...
    (thats a weird angle, makes ur car look like a short wheel base model haha :P)
    Quote Originally Posted by dingdong555 View Post
    Be careful not to hit yourself in the head whilst pulling
    My Ride, RUF60L
    SIDI sv6
    Jan 2010
    Penrith
    lol yeah was taken on the phone and i had trouble gtting it all in cause there is a wall behind me
    Pickle''s Avatar
    Pickle' is offline Donating Member
    VE Omega
    Apr 2009
    Sydney, NSW.
    purple caliper paint
    Thats what i got back when i asked the same question, Never got around to doing it though.
    VE SV6
    Apr 2010
    Quote Originally Posted by astroham View Post
    Set me back around $100 to get 2 G2 kits shipped from the states. Applied the 1st kit then sanded it back a couple of days later and then painted again with the 2nd kit.
    G2 Brake Caliper Paint System Set
    VE SSV 60th Ann
    Oct 2010
    Quote Originally Posted by Bradbd View Post
    I used this on my brakes. If you have a look at the G2 site there are tonnes of colours and if you have a particular colour you want and you have a paint code, they will match it.
    I was very lucky when I did mine as I had a mates 2nd set of SS caliper lying around. So I spent heaps of time prepping them with a wire brush for the end of the drill. I used prepsol first but found it didnt really clean the calipers. The wire brush was perfect. I tried a dremel one first but found it wore out too quickly. It was good for the tricker areas though.
    Then I just painted them as per instructions. G2 is a two part system you can just brush on or you can get a preval sprayer and spray it on like an aerosol. Then when fully dried we took the brakes off mine and put the new painted ones on.
    Thats a the best way
    However, I recently changed the look of the car and needed to get rid of the orange. So, leaving the brakes on, I rubbed them back with a scotchbrite pad. Then I cleaned them with prepsol, masked up the entire area of the wheel with newspaper and masking tape and sprayed the calipers with silver VHT brake paint. Looks a treat. Not perfect but unless you are doing a full on inspection of my calipers you'd n ever know. I didnt go to too much effort because I am getting my new brakes soon
    I'll post up some pics later of the stuff I have done
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Use VHT Caliper paint. VHT is the best auto paint IMO
    There is no such thing as stupid questions, Only stupid people.
    VE SV6
    Apr 2010
    Quote Originally Posted by bonners View Post
    You'd need to add a thinning agent to the paint in order for it to work through the preval sprayer but who knows how that would effect the integrity of the paint itself.
    VE SSV 60th Ann
    Oct 2010
    Don't remember it saying you needed too but then I never went that path so didn't research it. The how to video just shows them using one. The result would be better again than what I ended up with though.
  15. #15
    VE SV6
    Apr 2010
    Yeah I tried it but it didn't work straight out of the tin so I had to brush it on instead.
  16. #16
    VE V6 Ute
    Jul 2011
    Hunter Valley, NSW
    Quote Originally Posted by RUF-60L View Post
    black...
    I have a ute in that same colour, would dark green calipers look crap?
  17. #17
    VE SV6
    Apr 2010
    Quote Originally Posted by bundabergsangel View Post
    Yellow all the way
  18. #18
    VE SSV 60th Ann
    Oct 2010
    Poison ivy.. Yep, yellow would look great or the standard holden red (rolleyes). A specific colour like the poison ivy is really hard to match a colour to IMO
  19. #19
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    +1 contrasting calliper colours look good - unless the car is black, I wouldn't be matching the body colour to the brake colour. Yellow would look hot - but a really rich yellow - I'm thinking mustang yellow or lambo diablo yellow - just the brightest, fullest yellow you can find - nothing half arsed. Black would work also. Red and green would just look like a christmas theme.
  20. #20
    VE SSV 60th Ann
    Oct 2010
    Sorry tin, dont agree with black. Kind of gets lost behind the wheel. Def agree with the yellow and mustard.
    So Santa is driving a VE ....lol
  21. #21
    VE V6 Ute
    Jul 2011
    Hunter Valley, NSW
    Quote Originally Posted by TinSnips View Post
    Someone should tell that to bloody Holden. Try doing interior work to match the car (when it's Poison Ivy) with all the lights being red. Looks stupid as.
  22. #22
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Send Phreddy a PM. He does light and LCD screen colour changes.
    How To Contact Phreddy
  1. vt brake upgade .abs calipers* ar all vt calipers abs ready
    By justbad4you in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2011, 09:56 PM
  2. Red Brake Calipers
    By christopherVYpaul in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-08-2010, 11:39 AM
  3. VS brake calipers on a VN
    By Philth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2009, 08:54 PM
  4. brake calipers
    By vr-man in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2008, 08:58 PM
  5. brake calipers. loss of brake power
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 11:55 PM
