Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By RUF-60L
Thread: Hood Seal
    Luke V8's Avatar
    Luke V8 is offline AKA Luke!
    VE Commodore SSV
    Feb 2011
    Default Hood Seal
    Hi All,
    For those that have an OTR CAI (VCM for me) ... When you installed it, did you remove the hood seal? I've had no issues with increased engine temp but looks like it could potentially restrict air flow?
    ve ssv silver
    May 2011
    North WA- Karratha
    yeah id like to know this also, i brought a vcm otr friday. and havent fitted it yet, due to a fractured femur not nice.. but yeah did u fit it yourself?
    VE MY10 SSV Sportwagon M6
    Jul 2010
    RUF-60L's Avatar
    RUF-60L is offline Donating Member
    2008 VE SS
    Nov 2010
    Quote Originally Posted by VooDooWagon View Post
    I have the VCM otr and my hood seal is just cut away from the front of the otr.
    Same with mine, cept mine is duspeed
    Sidenote: iPhone corrected duspeed to 'diapers' lol
    Quote Originally Posted by dingdong555 View Post
    Be careful not to hit yourself in the head whilst pulling
    My Ride, RUF60L
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Quote Originally Posted by mitchelljdunne View Post
    Yeah is actually pretty easy mate - did loose a chunk of my wrist tho lol the base of the old box is a bitch to pull out as the battery terminal catches it. Make sure you retain screws. The instructions are pretty good
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Cheers guys will trim that now.. Its torrential rain here at min hope the cai will be ok lol (waiting to pick mrs up)
    ssv183's Avatar
    ssv183 is offline BAZINGA
    SSV CBR1000rr
    Mar 2011
    South Aus
    yep took mine off completely. have noticed the bonnet lining is rubbing on the otr a little so thinking about one of the hood infils........anyone have one?
    Dont put this SH*T on You tube or nuthin ....
    bladerunner's Avatar
    bladerunner is offline AUSTRALIAN MADE AND OWNED
    VE SS UTE
    Nov 2010
    brisbane nth
    Quote Originally Posted by ssv183 View Post
    yep i have one because of that problem,piss easy to install.you might want to rethink about removing the weatherstrip completely though, i did that at first and ended up with a filthy engine bay. i just trimmed it to fit either side of the otr which is a case of simply trimming it about 12mm past where it push's into the bonnet, you will see what i mean when you have a look at the strip location vs the otr position. i also put in the infill panel on the wheel arch where the factory one sits
    im out of my mind at the moment...please leave a message
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    I just went out last night and cut the section that could potentially prevent air getting to the induction.. 2 second job.
    Strange about some of you having to use the infil?.. i thought that was more of an issue if you had a supercharger...
    Although car decided to spit the dummy last night... check engine light. Still running fine so not majorly concerned, guessing its just spazzing out due to extra air.... but there's a thread on that lol
  1. Vr front gearbox seal leaking after new front seal replaced
    By pete30nz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2011, 06:18 PM
  2. Door Seal or Window Seal
    By crackah in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-10-2010, 09:57 PM
  3. Fuses Under The Hood!
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 05:53 PM
  4. Vc hood
    By -vkhg in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-12-2006, 06:22 PM
  5. Hood Mod/ How to mount a hood scoop? HELP PLZ!
    By soulyouth in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2005, 03:29 PM
